I agree with Dave.... iPhoto may not be the best program to use to extract EXIF data.... I use PhotoME to view exif data and using that, I can see that DNGs have a robust EXIF data section that really needs the proper program to view them.
Here's an example on how much EXIF data is available in a DNG file using PhotoME:
[ PhotoME ]
PhotoME version: 0.79 (Build 752)
[ Overview ]
File name: D:\My Pictures\TCPC 3-24-08\IMGP7432.DNG
File type: Adobe Digital Negative
File size: 31,063 KB
Creation date: 3/24/2008 20:32
Last modification: 4/6/2008 10:33
Make:
PENTAX Corporation
Camera: PENTAX K20D
Lens: TAMRON 28-300mm F3.5-6.3 Ultra zoom XR
Software: K20D Ver 1.00
Dimension: 4864 x 3136 px (15.3 MP)
Focal length: 300 mm (equiv. 450 mm)
Aperture: F9.5
Exposure time: 1/125"
ISO speed rating: 200/24°
Program: Manual
Metering Mode: Pattern
White Balance: Auto (Daylight)
Flash: Flash did not fire, compulsory flash mode
[ Image ]
New subfile type: Reduced-resolution image data
Image width: 160 px
Image height: 120 px
Number of bits per component: 8, 8, 8
Compression scheme: uncompressed
Pixel scheme: RGB
Manufacturer: PENTAX Corporation
Image input equipment model: PENTAX K20D
Image data location: 0x0001AFA6
Orientation of image: 90° CW (left/bottom)
Number of components: 3
Number of rows per strip: 120 rows
Bytes per compressed strip: 57600 bytes
Image data arrangement: Chunky Format (Interleaved)
File change date and time: 2008-03-24 20:32:51
SubIFD Pointer: 0x0001AB96, 0x0001AD38
Exif IFD Pointer: 0x0001AE40
DNG Version: Version 1.1.0.0
DNG Backward Version: Version 1.1.0.0
Unique Camera Model: PENTAX K20D
Color Matrix 1: [1.8300, -0.5353, -0.2780], [-0.4767, 1.3199, 0.0348], [-0.1808, 0.4165, 0.2996]
Color Matrix 2: [1.0958, -0.1500, -0.1248], [-0.6662, 1.5431, 0.1203], [-0.2135, 0.4073, 0.7496]
Analog Balance: 1, 1, 1
As Shot Neutral: 0.65641, 1, 0.717087
Baseline Exposure: 0.5
Baseline Noise: 1
Baseline Sharpness: 1
Linear Response Limit: 1
Shadow Scale: 1
DNG Private Data: 0x00001B96
Calibration Illuminant 1: 17
Calibration Illuminant 2: 21
[ Additional Image Data (1) ]
New subfile type: Not set
Image width: 4864 px
Image height: 3136 px
Number of bits per component: 16
Pixel scheme: CFA (Color Filter Matrix)
Image data location: 0x0013DC32
Number of components: 1
Number of rows per strip: 3136 rows
Bytes per compressed strip: 30507008 bytes
CFA Repeat Pattern Dimension: Horizontal repeat pixel unit: 2, Vertical repeat pixel unit: 2
CFA Pattern 2: [Blue, Green], [Green, Red]
CFA Plane Color: RGB
CFA Layout: Rectangular (or square) layout
Black Level Repeat Dim: BlackLevelRepeatRows: 2
BlackLevelRepeatCols: 2
Black Level: 0, 0, 0, 0
White Level: 4095
Default Scale: DefaultScaleH: 1
DefaultScaleV: 1
Default Crop Origin: DefaultCropOriginH: 8
DefaultCropOriginV: 8
Default Crop Size: DefaultCropSizeH: 4672
DefaultCropSizeV: 3104
Bayer Green Split: 0
Relative strength of the camera's anti-alias filter: 1
Best Quality Scale: 1
Active Area: Top: 0 px
Left: 0 px
Bottom: 3136 px
Right: 4864 px
[ Additional Image Data (2) ]
Image width: 4672 px
Image height: 3104 px
Compression scheme: JPEG
Pixel scheme: YCbCr
Image data location: 0x000290A6
Number of rows per strip: 3104 rows
Bytes per compressed strip: 1133452 bytes
Color space transformation matrix coefficients: 0.299, 0.587, 0.114
Subsampling ratio of Y to C: YCbCr4:2:2
Y and C positioning: Co-Sited
Pair of black and white reference values: [0, 255, 128, 255, 128, 255]
[ Camera ]
F number: F9.5
Exposure program: Manual
Date and time of original data generation: 2008-03-24 20:32:51
Date and time of digital data generation: 2008-03-24 20:32:51
Shutter speed: 6.97 Tv (1/125")
Aperture: 6.5 Av (F9.5)
Exposure bias: ±0 EV
Metering mode: Pattern
Lens focal length: 300 mm
Sensing method: One-chip color area sensor
Custom image processing: Normal process
Exposure mode: Manual exposure
White balance: Auto
Focal length in 35 mm film: 450 mm
Scene capture type: Standard
Contrast: Hard
Saturation: Normal
Sharpness: Hard
Subject distance range: Close view
[ Manufacturer notes ]
Pentax Version: 41.2.0
Pentax Model Group: Group 1 (DSLR series & Various Optio models)
Preview Image Size: 640 x 480
Preview Image Length: 22700 bytes
Preview Image Start: 0x00005EDC
Pentax Model: K20D
Date: 2008-03-24
Time: 20:32:51
Quality: RAW
Flash Mode: Off; Internal
Focus Mode: AF-S
AF Point Selected: Fixed Center
Exposure Time: 1/125"
F Number: F9.5
ISO: 200/24°
Exposure Compensation: ±0
Metering Mode: Multi-segment
Auto Bracketing: 0 EV, No Extended Bracket
White Balance: Auto
White Balance Mode: Auto (Daylight)
Focal Length: 300 mm
Saturation: Normal
Contrast: Med High
Sharpness: Med Hard
World Time Location: Hometown
Hometown City: Los Angeles
Destination City: Los Angeles
Hometown DST: No
Destination DST: No
DSP Firmware Version: Ver 1.00.00.01
CPU Firmware Version: Ver 1.00.00.01
Effective LV: 12.5 LV
Picture Mode: Manual; 1/2 Ev steps
Drive Mode: Single-frame; No Timer; Shutter Button; Single Exposure
Color Space: sRGB
Image Area Offset: x = 8 px, y = 8 px
Raw Image Size: width = 4672 px, height = 3104 px
Preview Image Borders: top = 28, bottom = 28, left = 0, right = 0
Lens Type: TAMRON 28-300mm F3.5-6.3 Ultra zoom XR
Camera Temperature: 30 °C
AE Lock: Off
Noise Reduction: Off
Flash Exposure Compensation: ±0
Image Tone: Bright
Color Temperature: Not set
SR Result: stabilized
Shake Reduction (Setup): 7
Shutter Release Half Press Time: 1.12 sec
SR Focal length: 300 mm
Shutter Count: 1828
Black Point: [0, 0, 0, 0]
White Point: [12480, 8192, 8192, 11424]
Picture Mode 2: Manual
AF Point Mode: Fixed Center
Focus Mode 2: AF-S
AF Point Selected 2: 32
ISO Floor: 200/24°
Drive Mode 2: Single-frame
Exposure Bracket Step Size: 2.0
Bracket Shot Number: n/a
AE Exposure Time: 1/120.7"
AE Aperture: F9.5
AE ISO: 200/24°
AE Xv: ±0 Ev
AEB Xv: ±0 Ev
AE Flash Tv: Not available
AE Program Mode: M, P or TAv
AE Extra?: 0
AE Metering Mode: Multi-segment
Flash Exposure Comp. Used: ±0 Ev
Lens Kind / Version (LC0): 2 / 8
Lens Data (LC1): 220
Distance Code Data (LC2): 49
K-Value (LC3): 116
Near Distance Abberation Correction Data (LC4): 103
Light Color Aberration Correction Data (LC5): 8
Open Aberration Data (LC6): 8
AF Minimum Actuation Condition Data (LC7): 98
Focal Length Data (LC8): 122
Nominal AVmin / AVmax Data (LC9): 11 / 12
mv' nv' Data (LC10): 120
AVC 1/EXP Data (LC11): 40
mv1 Avminsif Data (LC12): 2
AVmin Data (LC13): 84 (F6.1)
UNT_12 UNT_6 Data (LC14): 98
Incorporated Flash Suited END Data (LC15): 251
Flash Status: 0
Flash Mode: Off (241?)
External Flash Mode: 63
Internal Flash Magnitude: 0
TTL D/A A-ch Up: 0
TTL D/A A-ch Down: 0
TTL D/A B-ch Up: 0
TTL D/A B-ch Down: 0
AE Metering Segment 1: ~3 LV (center)
AE Metering Segment 2: ~2 LV (center edge)
AE Metering Segment 3: ~2.6 LV (upper, mid-right)
AE Metering Segment 4: ~2.5 LV (upper, mid-left)
AE Metering Segment 5: ~1.3 LV (upper, right)
AE Metering Segment 6: ~2.5 LV (upper, left)
AE Metering Segment 7: ~2 LV (mid-right)
AE Metering Segment 8: ~1.4 LV (mid-left)
AE Metering Segment 9: ~1.3 LV (right)
AE Metering Segment 10: ~2.3 LV (left)
AE Metering Segment 11: ~2.3 LV (lower, mid-right)
AE Metering Segment 12: ~2.3 LV (lower, mid-left)
AE Metering Segment 13: ~2.1 LV (lower, right)
AE Metering Segment 14: ~2.3 LV (lower, left)
AE Metering Segment 15: ~2.9 LV (top)
AE Metering Segment 16: ~2.8 LV (bottom)
WB RGGB Levels Daylight: [13140, 8192, 8192, 10693]
WB RGGB Levels Shade: [14984, 8192, 8192, 8136]
WB RGGB Levels Cloudy: [13930, 8192, 8192, 9454]
WB RGGB Levels Tungsten: [8431, 8192, 8192, 19838]
WB RGGB Levels Fluorescent D: [17388, 8192, 8192, 10073]
WB RGGB Levels Fluorescent N: [14754, 8192, 8192, 11468]
WB RGGB Levels Fluorescent W: [13766, 8192, 8192, 14258]
WB RGGB Levels Flash: [13930, 8192, 8192, 10073]
Pentax Model: K20D
Manufacture Date?: 2008-01-05
Model Revision?: 2.1
Internal Serial Number?: 22606
Power Source: Grip Battery
Battery States: Body Battery: 4; Grip Battery: 4
Battery A/D Body No Load: 186
Battery A/D Body Load: 176
Battery A/D Grip No Load: 187
Battery A/D Grip Load: 178
AF Points Unknown 1?: Center
AF Points Unknown 2?: Center, Bit 13?, Bit 15?
AF Predictor: +45
AF Defocus: 33
AF Integration Time: 70 ms
AF Points Unknown 3?: Center (horizontal)
AF Points In Focus: Center (vertical)
WB BA compensation: ±0
WB GM compensation: ±0
Alex
