01-20-2007, 01:31 PM   #1
K10D Firmware 1.10 works great
love having the wireless flash back...also love the ISO via control wheel in Av and Tv mode and the ability to change ISO via the OK button and control wheel.
update went flawlessly.
Enjoy the new features.
01-20-2007, 01:46 PM   #2
vievetrick's Avatar
what flash are you using?
01-20-2007, 02:38 PM   #3
QuoteOriginally posted by vievetrick Quote
EF-500DG Super
and a FGZ-360
in case you didn't notice the 1.0 firmware didn't allow the on camera flash to act as a controller.
the K10D (like the ist D) now allows use of the on camera RTF to act as a controller for the wireless flash system. Now you don't need 3 $200 flashes to operate a the wireless as a two flash setup. You can use the on camera RTF to fire 2 wireless slaves.
here are the other updates:
Firmware Version 1.10 for K10D
The following function has been added in version 1.10
① Wireless control of external flash through built-in flash.
 How to set
  ・Press Fn button and four way controller key ( )
・Flash mode selecting screen display
・Select Wireless mode
・ Flash discharge method can select by [ Flash in Wireless Mode] in the custom menu
1 ON Built in flash works with master
discharge
2 OFF Built in flash works with controller
discharge
・ HS(High speed sync)in not available
・ Select SLAVE 1 in Wireless slave mode when use
AF540FGZ or AF360FGZ
  How to use: Same as using two external flash, refer to the operating manual
② Instantly return to centre AF point by one push of button in AF select mode.
[Center of AF Point] is added to the AF function
In the custom menu
When AF point switching dial set to “SELECT”,
AF point is set to Center
③ Possible to change ISO setting by dial at TV/AV mode.
④ ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
・ ISO setting is being displayed in the view finder and on the LCD panel when setting the P/Tv
Av/M/B/X mode and then ISO can change by turning e-dial.
・ Possible to change to AF ISO by pressing green button in P/Tv/Av mode.
⑤ Green button function in M mode is available at TAv mode (Hyper manual).
・ Tv/Av value can set automatically when press green
button in TAv mode.
With this change, the name of [Green button in M] change
to [Green button in TAv & M] in the custom function
⑥ AV and TV switch by dial at P mode.
   The item No.2 is added to the [e-dial in Program] in Custom menu.
With this change, Av can change by front dial and Tv can change by rear dial.
⑦ Instant return to the default value by green button at strobe light compensation.
 Amount of flash compensation return to the initial value (0.0) by pressing green button when
display flash mode screen.
01-20-2007, 02:40 PM   #4
Also:
PENTAX DIGITAL CAMERA INFORMATION
Downloading of Firmware
Latest K10D Firmware Update
January, 2007
Thank you for using a PENTAX K10D digital camera.
PENTAX wishes to announce the release of Firmware Update Software Version 1.10 for K10D.
Firmware in this document is the software that runs inside digital cameras.
Changes to V1.10
1. Wireless control of external flash through built-in flash.
2. Instantly return to centre AF point by one push of button in AF select mode.
3. Possible to change ISO setting by dial at TV/AV mode.
4. ISO setting change by dial while the ISO setting is being displayed on the LCD by pushing OK button.
5. Green button function in M mode is available at TAv mode (Hyper manual).
6. AV and TV switch by dial at P mode.
7. Instant return to the default value by green button at strobe light compensation.
The following contents have been corrected.
1. In rare case, vertical stripe at long time exposure.
2. Released “B exposure” and show battery empty sign when using B mode.
* How to operate the additional functions, Click Here
Caution : Only K10D users are permitted to download the firmware update.
Name PENTAX Firmware Update Software for K10D
Registered name K10v110w.exe ( For Windows Kbytes) , k10v110m.hqx ( For Mac Kbytes)
Applied product
K10D ( Version 1.00)
To check the version number, turn your camera on while holding down the MENU button. The version number will appear in the center of the LCD screen.
Updated firmware file For Windows : LHA self-extract file, For Mac : BinHex type
Release date 2007/1/23
Copy right PENTAX Corporation
01-20-2007, 02:45 PM   #5
vievetrick's Avatar
I got all the technicall info and don't have the K10 yet but read on DP people could not get the Sigma 500 to flash wireless with the update. Your saying it is working? how are you getting it to work? I ask for others and for myself as hope to get K10 soon and have the Sigma 500 DG SUPER, Is your rechipped for use with K10? I know lot of question for someone without the camera. But, If I don;t ask other will I am sure.
01-20-2007, 05:45 PM   #6
I have only tested with the 360 thus far, my EF 500 didn't need to be rechipped as it was a serial # above the required.
i will test the 500 tonight or tomorrow and let you know if it works.
if not i am sure sigma will rechip it so i'm not worried. even if i had to pay $25 or so I'd be happy.
01-20-2007, 05:57 PM   #7
Hmm, thanks for asking. i just checked (couldn't wait). And yep, you are right. The flash fires as a slave but it doesn't expose properly. I think it's firing on the first P-TTL test flash.
so i will contact sigma and see if this is fixable. I'm sure it is.
Anyway, it works perfectly with the 360FGZ. So for now I still only have a 1 flash wireless system. while i like the size of the 360, the lack of swivel is a major issue, i'd have prefered the 360 didnt work. but since i paid about $75 for the 360 I'm not too upset.
01-22-2007, 11:40 AM   #8
slip's Avatar
Is this an officially released firmware?
if it is, do you have the link?
I spoke to pentax canada and they told me that it isn't released as of their knowledge.
they also told me that my warranty would be void if I installed the firmware prior to the release date....
thanks
randy
01-22-2007, 12:03 PM   #9
RBellavance's Avatar
Randy,
the firmware is not official yet, but has been leaked. According to this:
Official embargo date and time 01:00 GMT on 23rd Jan [n/t]: Pentax SLR Talk Forum: Digital Photography Review
the actual release will be at 01:00 GMT tomorrow.
I have downloaded the leaked firmware out of curiosity, but have not installed it.
01-22-2007, 12:06 PM   #10
Hi Randy, There is a big thread (several of them as a matter of fact) over at DPR. Seems that it was leaked by a Pentax sombody over in Europe somewhere. I think that nobody has had problems with it. However the official release is due out tomorrow if I read everything correctly.
NaCl(patience is a virtue, I'm told)H2O +
01-22-2007, 12:44 PM   #11
slip's Avatar
thanks everyone!
without going through all the DPR stuff, any idea which website the firmware will be on?
pentax canada hasn't updated their site since last fall.
thanks
randy
01-22-2007, 01:06 PM   #12
Well DPR usually posts all the official firmware updates on it's home page. So I'd check there tomorrow. In addition I'm sure Pentax USA will also post the firmware ugprade, at least they have the K100D firmware upgrade up.
Pentax Imaging: K10D - Digital SLR - Digital - Cameras by Pentax
NaCl(hope that helps)H2O
01-22-2007, 04:25 PM   #13
I went to the Pentax Imaging site about an hour ago and the formware update was there. While waiting for my battery to charge I looked again and it is gone. Interesting.
01-22-2007, 08:32 PM   #14
4shared.com - file sharing network - free file search - K10D
click the link if you cannot wait.
no problems with it and happy to have the functions for a few days in advance to play around.
everything is useful, especially the expanded ISO functions and custom settings.
camera, control, dslr, iso, k10d firmware, love, photography, wheel
Stop-down metering not working with extension tube on K-5 (works on K10d) Beau Troubleshooting and Beginner Help 3 09-13-2011 04:37 AM
Flash - how to know if it works in pTTL/auto with my K10d? José Ramos Flashes, Lighting, and Studio 8 05-01-2011 01:36 PM
this diy trigger works great slip Pentax Camera and Field Accessories 7 01-23-2011 06:43 AM
Eye-Fi Home Video 4Gb works great on the K-x! chicagonyc Video and Pentax HDSLRs 5 02-13-2010 02:51 PM
Metz 58 wireless not working? Metz 48 works great? Ideas? ksignorini Flashes, Lighting, and Studio 6 02-07-2010 05:33 PM
All times are GMT -7. The time now is 05:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
