04-07-2008, 11:14 PM   #1
K200D vs K10D : image quality, AF speed
Hello
I consider buying a SDM 50-135 and a new body to replace my K100D.
Who could compare both the K10D and the K200D, regarding
- image quality (I shoot in RAW) ?
- AF speed ?
- any other main reason to choose (I already know the K10D has a better viewfinder)
Thank you for your help
04-07-2008, 11:34 PM   #2
JMS
In RAW format, image quality should be identical, as the two cameras use the same image sensor.
04-08-2008, 05:12 PM   #3
Arpe's Avatar
AF speed on K10 will probably be faster due to bigger battery.
04-08-2008, 06:38 PM   #4
QuoteOriginally posted by Arpe Quote
Bigger is not better.
AF speed is the same when using 1.5v batteries (Lithium, or Alkalines at the very start). Rechargeables slow it down a bit (1.2v).
I think the K200D is a bit smaller. Other than that it might have better SR, and it has focus adjustments, larger/better screen, 1100 pics on one battery set, better Dust Removal, low speed burst mode, but you loose on the RAW buffer (5 frames less).
af, camera, dslr, image, k10d, k200d, photography
High Speed Flash on the K200D cdurfor Pentax DSLR Discussion 1 04-26-2010 07:22 AM
For Sale - Sold: Split Image Focus Screen Pentax K10D K200D K20D K100D annod Sold Items 7 10-12-2009 09:05 AM
AF speed of the K20D compared to K200D LeDave Pentax DSLR Discussion 1 06-29-2009 03:42 PM
about K200D shutter speed soulman Troubleshooting and Beginner Help 2 05-31-2009 02:06 AM
K200D Write Speed Biro Pentax DSLR Discussion 4 01-09-2009 04:47 AM
All times are GMT -7. The time now is 03:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
