Originally posted by schnitzer79 thanks for the replies guys.just went for the 7.4V one since its the same voltage on the OEM one.
They will all be the same voltage as Lith Ion batteries for a lot of devices start at 3.7 v. They then "arrange" them to 7.2 volts. Pentax does this arrangement.
The "thing" you should look for is the 1050 mah. This can vary a lot. The higher the number, the longer that battery will last in terms of one charge.
Some 3rd party batteries claim 1400 mah. I have seen a few test here on the forum where that 1400 was more like 800 or 600. This where things get dodgy with all the mfg claims.
So, in the end, the safest route is going with the OEM. I personally always carry backups to many things. So, even if my back up is a 600 mah 3rd party piece of crud, I can still get a couple of hundred more shots if needed.
