01-23-2014, 11:56 PM   #1
schnitzer79's Avatar
Firmware update issue on K-50
Hi,
Last night I attempted to update the fw (v1.01) on my K-50 and something a little strange happened. After the update completed and the camera turned off, I then proceeded to take out the SD Card to format it on my PC (couldve done so on the camera but it didnt occur to me at the time). I then tried switching off and on the camera again (since it was in the ON position but it was basically shutdown after the update). It wouldnt turn ON. I took out the battery and put it back in again and nothing. I froze for a minute thinking that my camera had become inoperable. I then put the SD card and switched it on again and everything came back on like normal. I checked the firmware and it was the new one, and i took a couple of pics and everything looked fine.
Is that normal? Doesnt the camera let you know that there is no SD card in the slot?
01-23-2014, 11:59 PM   #2
crewl1's Avatar
Could it be the card door was open? Pentax DSLR's I have do not fire up if the door is open, it must be closed, card or not.
01-24-2014, 12:00 AM   #3
QuoteOriginally posted by crewl1 Quote
hmm...i cant remember to be honest. you could be right. i will check it when i get home.thanks!
01-24-2014, 07:16 AM   #4
Oldbayrunner's Avatar
QuoteOriginally posted by schnitzer79 Quote
Hi,
Yes it does... There is an indicator at the bottom right side of your LCD screen that will be a red rectangle with a line through it.
From the caution section on page 53 of your manual;
"Be sure to fully close the card cover. The camera will not turn on if the card
cover is open."
01-25-2014, 05:51 AM   #5
yep the problem was the card door was open doh!
camera, card, dslr, firmware, firmware update issue, k-50, photography, sd, update
Firmware update issue with ist D socrates Troubleshooting and Beginner Help 4 06-29-2013 04:21 PM
Firmware Update Issue on my K7 dec Troubleshooting and Beginner Help 2 03-08-2013 04:19 PM
Unable to install firmware update v1.02 on K-x califgrll Pentax DSLR Discussion 10 01-15-2011 09:59 AM
Can a firmware update really fix the AF issue???? tbirdas Pentax K-5 4 12-30-2010 01:10 AM
Picture slow to show on LCD after K-7 firmware update jboyde Pentax DSLR Discussion 2 07-29-2010 12:58 PM
All times are GMT -7. The time now is 12:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
