Originally posted by TER-OR The Sigma 8-16 is a brilliant lens. UWA lenses are specialties, though, and may not be what your client wants to see. It does have its own special rendering. At 16mm it's very wide but at 8 it highly distorts the edges and gives a fisheye in the center - the effect is very cool but for a convention setting? I don't know if your client will want to see this.
The ISO performance of the K5 can let you get indoor pictures with that 18-135, it won't be a problem. You won't be shooting at ISO 100, but at 800 or even 2200 there's very little noise. If you want to use two bodies, the UWA lens is one to consider. A good portrait lens is another to consider.
I wouldn't rent a 16-45, it's not worth the money. Buy one instead. Another option is something in the 20-30mm range. I have a Sigma 28mm f1.8 which I really like indoors, up close and as a "what the eye sees" lens. Their 30 is also supposed to be very good. I've used the 28 indoors in dimly lit hotel settings wide open and have been VERY impressed.
Oooops I should have mentioned that I just wanted an 8~16mm basically for my own personal use....lol
I actually want to use tbe 16 ~50mm for this shoot.
I have decided to rent the 16 x 50mm 2.8 and the 50 x135mm 2.8 for this shoot, and for a couplr reasons.
1- I really dont know how much I will get to move around so I need the flexibility of the zooms
2-the faster lenses will be needed in such a low light situation
3- the client is paying for the rental, if I had to pay then I would most likely just invest in the lenses(which I am planning on doing when I reinvest my proceeds from my shoots)
4-i have been wanting tne two lenses for a while now, so this will give me an opportunity in a real world shooting situation to try them out before I buy.
also on another note I will be packing my 50mm,35mm manual lenses among most of the rest of my equipment, so if need be I will have access to them.
I will have the following set up during the shoot-
1-K-5 for my main camera with 16~50mm, and battery grip
2-K-X for secondary/back up camera with the 50~135mm on it, it will be sporting my Peak Design "Capture" to clip it onto my waste.
3-an old Quantaray (ol trusty) zoom flash with bracket for mounting off body, and dedicated module, I also picked up a small soft box for it hopefully I can get some practice before the shoot, therd wont be hardly any flash work at this shoot, but I wanna be prepared.
4-i will have a small Lowepro bag that is designed for just stowing a DSLR and an extra lens, around my waist worn like a butt bag, that will be there for accessories and extra neeced things
