Originally posted by audiobomber A blur filter is just a sheet of crystal placed in front of the sensor. It is not part of the sensor and has no effect on noise. Noise in the signal is generated in the sensor and the electronic circuitry only.
There are many reasons a K-5 and K-5 II image may be different, while using the same sensor, for example different ancillary electronics, different levels of non-defeatable noise reduction, different processing algorithms. The II and IIs have different resolution, same sensor. No other explanation makes sense.
I'm wasting my time here. See you around.
Let me summarize here. 3 people (and nearly a 4th) said there was no difference in noise between the K-5 and K-5 IIs. None of them has ever gone from the K-5 to the K-5 IIs, and only one of them even owns a K-5 IIs.
The two people who have owned both said they noticed lower noise with the K-5 IIs. Because Pentax never advertised this feature, they were both surprised to learn this, but discovered it nevertheless. However, because their discovery doesn't align with mainstream belief, they were chastised for mentioning it.
The difference can be seen simply by looking at the RAW studio shots on DPR. Each buyer needs to decide whether that difference is enough to matter to him. I'm not sure it is by itself, but altogether with the other improvements the K-5 IIs is a satisfying upgrade. I still have my K-5, but I'll always reach for my IIs first.
Originally posted by Hattifnatt So this means I should go for the K5IIs?
Actually, I think you should. I'm just not sure you should do it
before you update your lens kit. But if these limitations are really bugging you, you could get the camera first.
But I'd take care of the lenses first, because I spent at least 5 to 7 times the price of my K-x (which I paid full original price for) on lenses before I upgraded to the K-5. While I thought some might find it strange how much I spent on lenses for a K-x, I never thought it strange because my images got so much better. And then they barely improved when I finally spent all that money on a new K-5, because all the "IQ power" was in the lenses.
