02-03-2014, 05:03 AM   #16
schnitzer79's Avatar
its really difficult to see where the spring was so i can put it back so im sending it in
02-03-2014, 10:37 AM   #17
i mentioned in an earlier post that if i set the aperture on the ring manually (instead of the "A" setting) then the camera doesnt specify it.it just says F--. Im pretty sure that the camera used to specify it even though its been a while since I used the aperture ring.
I have set the settings in the menu for use of the ring before anyone asks. can someone verify this?
02-03-2014, 09:00 PM   #18
manacho2005's Avatar
It will show F-- if the ring is set to anything other than A. That's why it's called the "crippled" Kmount; it's missing the mechanical aperture link.
02-04-2014, 09:39 AM   #19
Otis Memorial Pentaxian
QuoteOriginally posted by schnitzer79 Quote
That is the expected behavior.
02-04-2014, 12:37 PM   #20
Yep ur right.i thought it was related to the fault. Just hadnt noticed before since the ring is always on "A"
03-13-2014, 12:49 AM - 1 Like   #21
finally my camera came back from repair.it took 5 weeks and they replaced the diaphragm control block and shutter block. that plus manual labour cost around 200 euro. thank god it was still under warranty.
i was hoping they would clean the sensor as well but they didnt. packing was pretty good though. havent tested it properly yet but took a couple of photos and it seems ok. fingers crossed!
aperture, battery, camera, dslr, issue, lens, lever, mirror, mirror flop, photography, samyang
Mirror flop issue Aeonflame Pentax K-r 33 02-04-2016 03:58 PM
Mirror Flop on the K-r - Plus additional strange issue Stoogie Troubleshooting and Beginner Help 11 08-23-2013 01:19 PM
k-r mirror flop guruh Pentax K-r 2 07-03-2013 07:13 AM
Questions about mirror flop Jeff Charles Pentax K-5 & K-5 II 11 02-05-2013 08:51 PM
The mirror flop problem revisited bwDraco Pentax DSLR Discussion 6 06-14-2012 10:27 PM
All times are GMT -7. The time now is 01:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
