02-01-2014, 08:08 AM   #1
schnitzer79's Avatar
Random mirror flop issue
I mounted my recently bought Samyang 8mm lens on my k-50 today and it was acting really strange.was taking a picture and the mirror would kind of lock up once for a couple of seconds. then it gradually started behaving more erratically and would lock up 2-3 times. i then dismounted the samyang and put back all of my other lenses (u can see them in my signature) and they were all fine. i put the samyang back on and the same thing happened.
during this mirror flopping issue, i noticed that the battery indicator would either show half full or a third full (yellow). i then proceeded to clean the contacts on the camera and also cleaned the samyang mount, put it back on and it was fine after that. after some searching on the net i came across some stories where the aperture lever would keep acting up.
sorry if this is an amateur question but is the lever supposed to be "unhinged" at the top?im assuming that once the lens is mounted, it pushes the black rectangle up and locks the arm in place, correct?i attached a picture so u can see.
anyway ive tried my camera once again with all lenses (incl.samyang) and everything is ok now. hopefully its just an issue with the dirty contacts and not a battery issue where i read somewhere on here, or even a problem with aperture lever.
hopefully someone can shed some light and let me know if there is something i can do to check if everything is ok.
02-01-2014, 08:23 AM   #2
Yes, your interpretation is correct.
02-01-2014, 08:48 AM   #3
manacho2005's Avatar
You might want to send that in. The guide rail you are pointing out in the picture looks to be pulled out of socket. It may work now, but for how long?
02-01-2014, 08:54 AM - 2 Likes   #4
It should look like this..
02-01-2014, 09:32 AM   #5
It appears to be a guide rail for the aperture stop down mechanism.
02-01-2014, 09:40 AM   #6
do you think it has anything to do with the mirror flop?
02-01-2014, 09:50 AM   #7
I wouldn't think so, unless the lens is being hit by the mirror....
02-01-2014, 11:03 AM   #8
bwDraco's Avatar
QuoteOriginally posted by schnitzer79 Quote
Actually, it does.
QuoteOriginally posted by DragonLord Quote
I was able to replicate mirror overrun behavior on a camera that is functioning normally by holding the aperture lever in the down position. This experiment proves that the real cause of the mirror flop issue is a jammed aperture control lever.
--DragonLord
02-01-2014, 11:22 AM   #9
interesting....so i guess im better off taking it back to the dealer then since its still under warranty.
im really gutted because my 2 lenses just arrived 3 days ago and didnt have the chance to test them out properly
02-02-2014, 12:25 AM   #10
when i press the shutter (with no lens on) the lever moves up and locks in place momentarily.something which can be seen clearly with a slow shutter speed. how is the lever acting in this case when its locked in the socket in the first place.im assuming the same way right?isnt this position of the lever dependant on what aperture you have your camera before you take the lens off?
EDIT:Also please note that the mirror flopping was that one time.It all stopped when I cleaned the contacts.However, I am charging the battery now to see if it does it again.
02-02-2014, 07:29 AM   #11
It is stabilized when it is seated in its socket. I'm sure it works fine the way it is, but you're looking at a near-future failure if it binds up just right. Without that mechanism, you'll always shoot wide open if it's stuck down, or compose and shoot at minimum aperture if it's lost completely.
Highly suggest sending it in.
02-02-2014, 12:09 PM   #12
ok i did a few more tests.the camera shoots fine and the photos are ok but im not sure about one thing.If i mount a lens with an aperture ring and i set the aperture manually on the ring, then the screen does not read the aperture value,it just read F--. yes, i changed the value to "2" for the aperture ring in the menu.i hardly ever shoot on another setting apart from "A" so i cant remember if the camera used to read the aperture or not in this case, so someone let me know.
I also attached another pic and a video.the pic shows something sticking out of the aperture lever when the lever is in the socket.should that black thing sticking out be there (shown by red arrow) ?
the video shows that the lever is stabilized in the socket when the shutter is pressed and then moves back down again.i had to use a shutter speed of 5 secs to show this properly.
if anything doesnt look right please let me know. I also read in an old thread somewhere on here that the aperture lever's position is down and only goes up when the shutter fires, so now im really confused.....
02-02-2014, 01:33 PM   #13
That lever shouldn't even move unless you have a lens mounted, so somethings definitely up. And the piece you're pointing out is very suspicious, looks like a spring that's been unsprung.
02-03-2014, 01:19 AM   #14
yep it does look like a spring thats come unhooked.any idea what could have caused it?
02-03-2014, 04:32 AM   #15
Possibly the stiffness of the 8mm, but it may have been overlooked in the factory.
aperture, battery, camera, dslr, issue, lens, lever, mirror, mirror flop, photography, samyang
Mirror flop issue Aeonflame Pentax K-r 33 02-04-2016 03:58 PM
Mirror Flop on the K-r - Plus additional strange issue Stoogie Troubleshooting and Beginner Help 11 08-23-2013 01:19 PM
k-r mirror flop guruh Pentax K-r 2 07-03-2013 07:13 AM
Questions about mirror flop Jeff Charles Pentax K-5 11 02-05-2013 08:51 PM
The mirror flop problem revisited bwDraco Pentax DSLR Discussion 6 06-14-2012 10:27 PM
All times are GMT -7. The time now is 11:02 AM. | See also: NikonForums.com, part of our network of photo forums!
