04-13-2008, 11:25 AM   #1
K20D - High ISO Noise Reduction - How? How much? When?
I'm a little confused by the two Noise Reduction settings in my new K20D. Here are my questions:
1. When (17.) Slow Shutter Speed NR is set to On, then the camera only applies noise reduction when the shutter speed is slower than 0.3 seconds. So, in Auto, will it apply noise reduction at higher speeds if it deems necessary?
2. (18.) High-ISO Noise Reduction works "...when shooting with a high sensitivity setting." How high is high? When is it applied? Is ISO 400 high enough for it to kick in? How about 800?
3. When shooting RAW, do these settings have any affect? Settings like "Saturation" have an effect on the RAW image, in so far as the image without any development modifications will be processed by ACR/Lightroom (for example) using the settings that come along for the ride. Is that the same with the NR settings?
4. Finally, how good is the in-camera High-ISO NR vs. software like Noise Ninja?
Thanks!
04-13-2008, 11:57 AM   #2
PFH
PFH's Avatar
NR is only aplied from 1600 and over, the best is to use the first two levels of NR. Otherwise you will lose too much details.
04-13-2008, 12:34 PM   #3
QuoteOriginally posted by PFH Quote
That's not correct. On page 78 in the manual it tells you that over ISO 3200 automatically has strongest selected as the noise reduction. I never found a spot where it tells us what our selection is for (i.e. ISO ? up to ISO 1600?).
04-13-2008, 12:59 PM   #4
falconeye's Avatar
ksignorini, so I found your question
In the early days of the K20D, myself (and others as well, I guess), thought that the NR settings would have any impact for RAW or RAW processing.
However, indications are now such that:
NR settings don't have any influence for RAW, except that the setting is stored in the meta. However, both LR and PPL seem to ignore this setting. Still have to check with LR 1.4.1 though.
JPEG quality with the K20D is excellent and meant for people wanting to avoid the post processing. I recommend the STRONG NR setting in those cases. I say this because if you want to maintain a certain flexibility to balance between noise and detail, it is better to shoot RAW anyway.
Early tests have measured K20D noise using RAW with NR settings enabled but missing to observe that it isn't in effect during RAW development.
04-13-2008, 01:14 PM   #5
OK, that's good to know.
Regarding the JPEG quality then, is **** the equivalent of something like a "12" in Photoshop terms? Just how very-little-compression is the **** version compared to the *** star version?
camera, dslr, image, iso, iso noise reduction, k20d, noise, nr, photography, reduction, settings, shutter
K-x high-ISO noise reduction: use it or do it in PP instead? richardm Troubleshooting and Beginner Help 5 10-28-2010 08:45 AM
High ISO - black and white - no noise reduction look kxuser Photographic Technique 43 04-08-2010 06:59 AM
Nikon high ISO noise reduction? MidwestMax Non-Pentax Cameras: Canon, Nikon, etc. 4 03-30-2010 02:09 PM
What do you guys use for high iso noise reduction? rustynail925 Digital Processing, Software, and Printing 38 12-04-2009 01:28 AM
High ISO Noise Reduction on K20D - Does it do anything in RAW? ksignorini Pentax DSLR Discussion 4 07-23-2008 03:53 AM
All times are GMT -7. The time now is 11:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
