Originally posted by EddyinGA When you process RAW files with PSE, do you process them in the camera, or in the card reader, before you import them to PSE?
When saving the files, do you save them to the camera/card reader as a new file?
I’ve taken a couple of shots, opened them to process and tried to save. When the dialogue box opens for the save, how do you save to the card and do you give the file a new .ext?
After the save, how do you close the dialogue box?
I’ll be really happy when PSE 5 for dummies comes out as it may have the answers to theses questions.
The help section in PSE 5 doesn’t seem to go into very much detail when it comes to using the RAW plug in.
Any help for me here?
What I do, is copy the pef files from the camera to a folder on my hard drive using a card reader. You can use the USB cable for this if you prefer. Once the files are safely on my PC, I delete the files from the card to be reused. All further work is done on the computer.
When you open PSE, click on Edit and Enhance photos (I'm assuming the interface in PSE5 is the same as PSE3)
If the file browser is not open then go to file/browse to open it. Navigate to the folder you saved your pef files to, and wait a few minutes while PSE reads all the files and creates the thumbnails (you can do all this in organizer also if you prefer).
Double click the pef file you want to edit, and it will open in ACR. Make what ever corrections you wish in ACR and when you are satisfied click open. This will open the file in PSE proper, where you can make other corrections, or just save the file in whatever format you wish.
One hint. Make sure you bring the file into PSE from ACR as a 16 bit file. There is a dialog box to set this. Do as much correction in 16 bits as the software will allow before converting to 8 bit mode. This will maximize your flexibility in manipulating the file.
Remember I'm working from PSE3, the PSE5 interface and features have changed a bit, but it should be close enough for you to figure it out.
Hope this helps and hasn't confused you even more
-Alan
