Originally posted by lister6520 I actually expended quite a lot of effort trying to solve it that way but found that while it was easy to get the display to show North when pointed to the North as soon as I turned the camera or even changed the elevation the amount of compensation changes.
Hm, thats damn tricky. But this mean if you compensate compass via software in one direction it will not match in other direction, the same issue... only if you could bypass compass at all and measure azimuth manually and feed this fixed data...
Originally posted by lister6520 I am thinking it will be straight NMEA ASCII strings except for some initial response to the camera interrogating the hotshoe. If so it should be quite easy to devise a PIC to alter the values within the relevant strings.
But it seems not. Shodan told he didn't find any trace of NMEA parser in FW. I aslo didn't find anything like that (strings gga, gsv, ggl, rmc...) I think almost all devices that process common NMEA have this strings visible in FW. Here are all strings containing "gps":
C:\GPS, GPS_DAT?.TXT, GPSMMII, GPSWCPVQ, GPS DATA FULL.
and one interesting string
"%02X:Calc Astor trace data."
can you see the typo? Astor instead of Astro. Or was it intended obfuscation?
