Originally posted by patarok I ll soon have a P-TTL Hotshoe Adapter Cable in my Hands... I will try the GPS on it anyways, because i am also looking forward to dismantle that adapter, because i will try to build a Hotshoe stage, so i can hook up gps and still use built in flash.
My first guess when i was reading about the problems you have with hooking up gps to a p-ttl adapter was:
Maybe it has to do with the conduction of the p-ttl cable respectively the resistance of the cables.
I've just received the new P-TTL cable and hopefully will find the time tomorrow to start working on it. I have however checked a couple of things regarding why the GPS won;t work with the cable. First thing I tried with the new cable and found that it does work - sort of. The camera recognises it and I can get the compass display but it updates very slowly and intermittently and I never get a GPS lock. So it seems some communication is getting through but it is garbled.
Out of curiosity I checked the cable capacitance and found that with the one I was using before (which doesnt work at all with the GPS I had between 300 and 500pf between any two conductors whereas with the new (and cheap) one it is more in the range of 120 to 240 pf, practically half (depending on which two conductors are measured).
If the signals are high impedance and/or open collector then even 100pf could be very significant if it is expected sharp rising/falling edges.
Resistance is less than 1 ohm in all cases. I just measured that with a multimeter, didn;t bother with a milliohmmeter as anything less than 10 ohms or so would normally be irrelevant in any case.
First thing I do will be to dismantle the cable and reassemble it with the two ends connected by very short single strand wires and see if the GPS is happy with that. If it is then I'll tap the wires with some sort of high impedance input stage.
