Originally posted by asce8 Shodan, can you also increase dynamic range of pentax k30 with your firmware?. I saw that some canon camera with magic lantern can do this!
Dynamic range is a function of the sensor and the amplifiers attached to it - I'd very much like to see where it's quoted that ML can increase the Dynamic Range.
I do know that on some bodies, ML can allow access to higher ISO settings, shutter speeds, and to shooting 'Raw' video. Raw video is basically full dynamic range and data per video frame, rather then having the dynamic range limited to REC709 standards.
And just to be clear for anyone reading who doesn't know, Dynamic Range is the number of stops difference between the darkest and lightest element on the frame that are not under or over exposed - the upper and lower limits of brightness that the camera can see at any particular ISO/Iris/Shutter speed combination.
