Closed Thread
Show Printable Version 230 Likes Search this Thread
04-20-2015, 01:40 AM   #466
QuoteOriginally posted by niceshot Quote
Its a shame so much effort has been put into this and ???? No valid RESULTS its a real shame. Seems completely pointless. As the hack that doesn't hack.
You better be trolling. I know practically nothing about this and I can still understand how bloody difficult it is.
04-20-2015, 10:59 AM   #467
Shodan's Avatar
@niceshot
Have you seen my work on GitHub? Do you know that you can write arbitrary code for the K30?
You sir are an idiot. I'll also PM you to mention the last bit again. I suggest others do the same...
04-20-2015, 11:42 AM   #468
. Alright Shodan I didn't mean to say that you didn't put a lot of effort, all I meant is it is a shame more didn't come of it. That does not mean I don't appreciate your effort, I do so plz accept this as an apology ok?
04-20-2015, 02:52 PM   #469
Shodan's Avatar
Fair play. You don't generally get an apology on the Internet
04-22-2015, 05:04 PM   #470
This message is for Shodan. Shodan I was able to use the debug to by pass an sd corridor problem there by allowing me to make useful a brand new k-30 with no actuations into a usable camera . S o thanks is in order.
04-29-2015, 08:34 AM   #471
Banned
K-S1 can do RAW video ?
04-29-2015, 10:30 AM   #472
aurele's Avatar
that could be very interesting
05-04-2015, 12:18 PM   #473
Banned
One of serial ports on K-30 is at base address 0xC0000040. Registers are similar for example to those described in CM71-10147-2E.pdf: 0xC0000044 - data register (16-bit), 0xC000004C - FIFO Control Register 1 (byte).
05-07-2015, 05:21 PM   #474
Banned
QuoteOriginally posted by marabella Quote
I have tried to access the debug menu on my K-S1 (see #383) with files from 00077850.400 to 00077850.900. No luck.
I have decompressed part of firmware. Debug menus are present. Last part of filename is .558, should try 00077850.558.
05-08-2015, 04:22 AM   #475
QuoteOriginally posted by bootcoder Quote
That's great news. Brilliant work.
Sad to say that I can't get it to open the debug menu. I have tried all the previously mentioned combinations for the .558 file. ANSI- [OPEN_DEBUG_MENU]/[DEBUG_MODE EN] - with/without CR plus the DEVELOP.MOD. Card door open/closed, ON in combination with menu button.
I can't test all possible permutations (20922789888000) between 16 buttons
Have you tried it yourself? Do you own a K-S1?
05-08-2015, 10:28 AM   #476
bobbotron's Avatar
This is pretty neat, very cool to see people working on this kind of project!
It would be amazing if Pentax created some kind of plugin architecture for their cameras, or open sourced part/all of the code. One can dream.
05-08-2015, 12:15 PM   #477
Banned
I have read here that you need to create file 00077850.558 with following content:
[DEBUG_MODE EN]
[SW_DEBUG_MENU EN]
[OPEN_DEBUG_MENU]
[VLENS_CONTROL]
[SCRIPT_EN_MODE EN]
with CR LF (or 0x0D 0x0A !) as end-of-line. Then create DEVELOP.MOD file (upper case is important! UPDATE: how to prepare file). Then power off camera, open card door and finally press-and-hold "menu" button and power on camera. Keep pressing "menu" until it shows menu.
I am not sure what model number K-S1 has, because it is not seen in firmware ?
No, because I do not have K-S1.
I decompressed only first 10MB out of 16MB firmware image, so missing important parts still. Somehow my tool gets messed up from 10MB...
05-08-2015, 01:52 PM   #478
Thank you for these hints - didn't expect this.
Have double checked everything. 77850 must be correct. It's the Hex to Dez value (0x1301a from ExifTool) for PentaxModel ID Value plus 000. I have crosschecked this with K3, K30 and K-5.
Thanks to: Pentax Tags
[DEBUG_MODE EN] or [OPEN_DEBUG_MENU] should work. Notepad should be good to create both files when deleting txt extension. Works with my K20D.
So far we have done everything that has worked with previous cameras. I can feel the faint smile of a Pentaxcoder over my shoulder while writing this:-).
I'm kidding. But I'm pretty sure they are watching this thread since it's start. May be that's why this way could lead to a dead end.
Good luck with the remaining parts and please email for testing. Not to forget thanks to shodan who did the initial and most valuable work.
05-08-2015, 03:34 PM   #479
Banned
What firmware version do you use ? Filename is 'C:\%08ld.%03ld' that is 00077850.558 for 1.10 K-S1 firm. After file C:\00077850.558 is found, it looks for C:\DEVELOP.MOD.
P.S. In addition to steps above, DEVELOP.MOD file must be 10 bytes long for K-S1 and have one of 2 possible contents (hex bytes):
Type 1: bytes 07 01 2C 1F 10 03 1E 16 05 2D
or
Type 2: bytes 07 1A 02 0A 19 18 1B 1C 05 11
I have no idea what the difference will be.
UPDATE:
Type 1: Development Menu 7 with firmware update is disabled
Type 2: Development Menu 7 is enabled
05-09-2015, 12:18 PM   #480
Hello bootcoder
Better to check but of course I'm using v.1.10.
Hmm, DEVELOP.MOD intentionally has no content and in Windows Explorer it's shown with 0 bytes.
It's the .558-file that has content.
Should I write the hex bytes into the .MOD? As ASCII? Makes no sense IMHO as all hex values starting with 0/1 are control codes.
BTW: I have tried [DEBUG_MODE EN] and or [OPEN_DEBUG_MENU] with CR or LF.
I exactly followed the instructions from all previously mentioned methods (K30, K5, K5II and K3).
Closed Thread
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 & K-5 II 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Film SLRs and Compact Film Cameras 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 03:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
