05-15-2015, 05:58 AM - 1 Like   #496
Hi bobbotron,
As you can see (link below) with:
2 cactus v5 or V6 (as remote shutter) and 1 or more V6 as flash trigger, you can use HSS with the right delay (for my K3&70-200 => 94ms).
I try from 1/180 up to 1/8000 with same delay and no curtain shadow !
Thx again to ClassA for helping with cactus products.
Hope it help
HyperSync / HSS with the V6 (without dedicated equipment) - Cactus Community
05-17-2015, 03:51 PM - 2 Likes   #497
Everyone: I've started some hacking on the FluCard, in case anyone here is interested. It's a Linux-based system, with ARM7 executables.
Link to thread: https://www.pentaxforums.com/forums/22-pentax-camera-field-accessories/295676...ml#post3256469
BTW, may I also suggest that any findings here are documented somewhere public, maybe at wikia.org? Digging thru this long thread has become quite difficult.
05-17-2015, 08:15 PM   #498
QuoteOriginally posted by tempelorg Quote
There is a WIKI
05-18-2015, 01:38 AM   #499
QuoteOriginally posted by bootcoder Quote
There is a WIKI
Oops, right. And it's even linked to in the first post. Meh, that's why I suck at this. I am not paying enough attention
It doesn't look like the Wiki hasn't been updated lately at all, though. My post was about asking all contributors to remember to add to such a wiki. Doesn't seem to happen. Or is this Shodan's private wiki?
05-18-2015, 05:07 AM   #500
I guess every person can register and contribute, isn't it ?
I will try to find time soon to add my stuff.
05-19-2015, 10:06 AM   #501
Has anyone tried to read the Lens data from a K-3? Because I tried and it doesn't seem to work - choosing the "LENS ROM DAT CAMERA=>SD" command from the debug menu doesn't write a file, and the display only flickers very briefly when pressing the OK button. On the other hand, on my K-5, the same command works, with the screen blacking out for about a second during the operation.
I wonder if this feature has been disabled in the firmware or if it's just me. I'd like to know if others tried and had success with the K-3.
05-19-2015, 11:09 AM   #502
bobbotron's Avatar
QuoteOriginally posted by novsky Quote
Hi bobbotron,
Hope it help
Totally, although that requires three cactus flashes. It would be nice if there was a "fire the flash regardless of flash sync speed ceiling" mode where it'd trigger your flash at higher speeds for compatibility with manual HSS flashes.
05-20-2015, 02:20 AM   #503
QuoteOriginally posted by bobbotron Quote
@All, sorry for the digression...
@bobbotron => Nope u don't need cactus flashes, i use that technique with 2xV5, 3xV6 (cactus triggers) and 1 Pentax 540 FGZ, 1 Metz AF 58 and 1 Metz AF 50 as flashes.
05-21-2015, 08:04 AM   #504
bobbotron's Avatar
Right! I reread that link, I get it now. Still, wouldn't be awesome if you could override the built in speed limit, and trigger a HSS flash directly via a sync cable or something?
05-22-2015, 04:55 AM   #505
K5 open debug , anybody can help me?
Hello
I opened debug mode in my k5 v1.15 with pk theter software, I made a too strong front focus correction -110Um .
now I have back focus and need to re open the debug mode. when I exit from debug mode, I closed debug mode
but now I cant open it with pktheter and the next files also donīt work
00077430.505
DEVELOP.MOD
into the file develop mode:[OPEN_DEBUG_MENU]
leaving card door open
what am I doing Wrong?
Thanks , and sorry Bad english
05-22-2015, 06:42 AM   #506
pasorro, my K-5 has an empty "DEVELOP.MOD" file and two files named "00077430.505" and "00077760.502", both with just "[OPEN_DEBUG_MENU]" inside. All files stored at the root of the SD card. I put that card into the K-5, leave the door open and turn the camera on. That opens the debug menu. No need for pktether.
It looks like you put the text into the wrong file.
05-25-2015, 08:19 AM - 3 Likes   #507
K-S1 movie encoder/decoder chip identified. It is famous "ribery" chip from Fujitsu. Bitrates up to 64 MBps could be possible, but huge work must be done before.
05-25-2015, 09:11 AM   #508
Do we have an actual part number? I would like to see a datasheet on its specs.
05-26-2015, 05:00 AM   #509
PiDicus Rex's Avatar
Which other models is that chip used in?
( Yeah, yeah, I'm readin' the Wiki too,.. )
05-29-2015, 12:44 PM   #510
QuoteOriginally posted by PiDicus Rex Quote
Used for example in Nikon D800.
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Pentax Film SLR Discussion 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 09:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
