10-30-2015, 01:32 PM   #541
QuoteOriginally posted by bootcoder Quote
Unfortunately, strings are here part of data segement and in the middle of other constants. So you can't insert something. But there is already support for many languages.
On that Canon I rewrote Finnish (Suomi) language messages with Czech. Of course I had to fit in total length of all strings but I can shift some messages a little bit. Also I have to check visual on display that the text is not running out of the bound...
BTW what do you want to do with this strings?
Here's my old Canon work but in CZ-only, maybe google translate helps..
http://rayer.g6.cz/hardware/a70.htm#A70FWH
10-30-2015, 08:12 PM   #542
Same string area can be found also in K30 firm: search for bytes 30h 51h 02h. So you can translate to Czech It was just one of two strange areas in firmware. Another one contain firmware for movie codec.
I really wish you had more english content and more people get knowledge about your work.
11-11-2015, 10:26 AM   #543
panonski's Avatar
Hello,
I didn't read all 37 pages so far, so forgive me, if there was a post about it already...
I have an experience with different camdrives in cellphones - just as a high end consumer, not developer. I remember in those days, how kids would pull out camdrives from SonyEricssonn phones, and change them to suite more better ...
They do a hell of the job - we have in the end , all kinds of manual possibilities - in ordinary phone!
But now, I have a real camera, and I miss one feature here ( have a Pentax K 3 ) - photographing in different aspect ratio ( something that I have on Olympus ) .
I find the 3:2 DSLR apect ratio is not so good when I'm shooting more art photos, because in portrait mode 3:2 just have to much vertical space, to be pleasant to eye...
Is there any kind of solution to do this with changes in firmware ?
Thanks and enjoy
11-11-2015, 11:54 AM   #544
Senior Moderator
Parallax's Avatar
QuoteOriginally posted by panonski Quote
No. As was mentioned in the 2 threads you started on the subject, one before you bought the camera and the other after the fact, no; the K-3 shoots only 3:2 aspect ratio stills.
11-11-2015, 12:06 PM   #545
panonski's Avatar
QuoteOriginally posted by Parallax Quote
Hope dies last
11-29-2015, 10:51 PM   #546
richandfleur's Avatar
That's the native aspect ratio of the sensor right?
So cropping that down is the only option here, whether in camera or in post, same end result.
12-02-2015, 12:50 PM   #547
Hi all,
I am a new user, but I'm reading stuff from this forum since some years. I have the opportunity to buy from a friend a used, but actually not-working, Pentax K-7. The camera is bricked: the user that owns it was upgrading the camera to a new official firmware, but he turned off the camera before it finished the process.
Is the camera recoverable? I don't want to start a new thread because I think this thread could help me to find the answer. I mean, there are a lot of things I can do with a "modified" firmware and the Debug Menu.
Is it recoverable? Or it is definitively died? Thank you in advance!
12-02-2015, 01:48 PM   #548
QuoteOriginally posted by gamma77 Quote
The first thing I would do is charge the camera battery, download the latest K-7 firmware, unzip it, copy the firmware to the root of an SD card, and attempt to perform a new firmware upgrade. If that works, problem solved.
12-02-2015, 02:19 PM   #549
The camera is fully bricked, so you can't even turn it on. The firmware itself got corrupted, I think. The camera doesn't turn on at all.
12-02-2015, 03:38 PM   #550
Doesn't turn on or doesn't turn on via the switch? It might power on if you do the update key combo.
12-02-2015, 04:10 PM   #551
It can happen that camera FW freeze so deep that it cannot be turned on via switch. Once it happened to me on my K-30. I though that battery is simply discharged but I tried to remove and reinsert it again and then I could turn it on normal way via switch. Battery indicator was at 1/2 so it was not fully discharged... I don't know why it happened...
I would guess that camera has some bootloader that is able to do a recovery flash but who knows how to activate. Maybe it would be enough to copy a file with right name on SD, maybe need to press something...
Also it can be programmed HW-way, if you disassemble it there would be probably testpoints that allow to connect a JTAG port and via JTAG chain it would be possible to programm the flash. But it's hard to do without any documentation. So I would rather buy another mechanically damaged camera and replace the circuit board in your camera.
12-02-2015, 11:53 PM   #552
Did you try to have batteries off the camera for few hours and reflashing? I necromanced my K100 from that way. Bootloader which loads FW update should be rather tough to kill. And use small (<2GB) SD card.
12-03-2015, 10:24 AM   #553
No, I just removed the pack for a few seconds, put back and it turned on normally. It was some FW bug/deadlock not damaged FW in the flash. I wrote it because I don't know if gamma77 did tried to remove his battery so it might be this stupid case
12-03-2015, 10:42 AM   #554
QuoteOriginally posted by anemone Quote
I don't have the camera here, but I suppose my friend tried it. I will contact him, but I'm pretty sure he tried this simple workaround.
QuoteOriginally posted by RayeR Quote
Thank you for your reply. I think the camera is completely dead. The only way perhaps is to use a JTAG, but I need at least a person that tried to figure out which are the correct pins. What a shame... An almost new Pentax K-7 bricked in this way. If somebody can help with a sort of complete restore of the software side of the camera, I'm here to learn. Anyway, everything you said was done (my friend tried to recover the camera in infinite ways, but nothing seem to work), at least I think.
LOL the camera is not mine, but I think that my friend tried it a lot of times, with different batteries and different ways. This is a simple troubleshooting that everyone tries before throwing away an almost new Pentax body.
Thank you mates.
12-03-2015, 02:24 PM   #555
Seriously, did he try the FW update key combo?
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Pentax Film SLR Discussion 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 06:15 AM. | See also: NikonForums.com, part of our network of photo forums!
