08-06-2016, 06:15 PM   #616
(not tested) pentax k-3II: for activation Debug Menu you need file 00077980.570 and DEVELOP.MOD (see above).
08-07-2016, 12:36 AM   #617
Thank you very much for your effort, bootcoder.
Now the natural open question is: What should be the combination for a K-1 with the new v1.2 firmware?
00077970.??? and DEVELOP.MOD
And could you please post how to find this out again?
I was posted somewhere along time ago, but I can not find it anymore. I remember that you can somehow read it in the firmware file and it changes with every new firmware revision.
08-07-2016, 11:30 AM   #618
QuoteOriginally posted by beholder3 Quote
For K-1 things are more complicated. It is similar to K-S1/2, where file alone is not enough. Do you have K-1?
There is no easy way to find it except disassembling/analyzing firmware.
08-07-2016, 01:33 PM   #619
QuoteOriginally posted by bootcoder Quote
I assume so, since the firmware decryption program fails on the K-1's firmware.
Yes, I have a K-1, but have no skills whatsoever in disassembly.
08-08-2016, 12:01 PM - 1 Like   #620
DELETED: contained error
see my newer post with updated instructions
08-09-2016, 10:06 AM   #621
Work O.K.
08-09-2016, 11:11 AM   #622
For K-1 to enter Debug Mode you should create files 00077970.560 and DEVELOP.MOD. File DEVELOP.MOD must be exact 10 bytes long and its content should be entered in file hexeditor:
EITHER hex bytes: 07 01 2C 1F 10 03 1E 16 05 2D enables Development Menu 1-6
OR hex bytes: 07 1A 02 0A 19 18 1B 1C 05 11 enables Development Menu 1-7
Then turn off camera, plugin this SD card. Leave card door open. Push "menu" button and switch On.
Post screenshots of camera entering debug mode as proof.
Sadly this does not work and the screen stays black.
08-09-2016, 11:39 AM - 1 Like   #623
UPDATED 09.08.16: note different file extension
  1. File 00077970.562 should contain [OPEN_DEBUG_MENU] and LF char.
  2. File DEVELOP.MOD must be exact 10 bytes long and its content should be entered in file hexeditor:
Then turn off camera, plugin this SD card. Leave card door open. Hold "menu" button and turn camera on.
08-09-2016, 12:18 PM - 2 Likes   #624
Many thanks and kudos to you, bootcoder.
Now it works. The two hex options you described actually lead the the very same result.
Using K-1 FW v1.20
We get 9 pages of development menu, which can be scrolled through via the backside e-dial.
And if you activate the debug mode there you get to one page of "Test Mode" as extra tab right before the custom settings (but I did not check if another "test mode" tab would appear with the other hex codes.
08-10-2016, 01:05 PM   #625
Using K-1 FW v1.20
Congratulations, enjoy your camera !
08-10-2016, 08:06 PM - 3 Likes   #626
And you found no Easter eggs in there, like a Tetris game or a Pokemon?
I am disappointed by Ricoh.
08-12-2016, 02:53 AM   #627
Can you tell me, how to find out the post-fix/extension like ".562" myself?
I found the description using frmdecrypt.exe, but that doesnt seem to work on the K-1 files as it exits with an error.
08-17-2016, 09:18 PM - 2 Likes   #628
wtigga's Avatar
Hey, that works for K3-II, but I only get one-page TEST menu with just a few settings. How should I change it to have a full developer menu? Something like beholder3 mentioned few posts ago.
What I'm looking for is a way to change region code, that (probably) will unlock GPS logging function on my Chinese version of K3II.
UPD: My bad, I should've looked for Region settings right after I turn camera instead of debug menu.
Did what I expected it to - now I have a GPS logging function working as it should be, despite Chinese government restrictions.
08-23-2016, 08:02 AM   #629
QuoteOriginally posted by wtigga Quote
Why your gov. restrict GPS logging on DSLR when every smartphone can do it? Can be this function turned on/off in camera menu?
10-07-2016, 02:58 PM   #630
UncleVanya's Avatar
QuoteOriginally posted by Fire Angel Quote
Thank you!
---------- Post added 06-19-16 at 09:57 PM ----------
OK, I have put the tables together for a PDF giving instructions for putting Pentax DSLRs into debug mode. I have only a few cameras of recent years missing from the list and if anyone can help fill these gaps please contribute. The missing cameras are:
K-3ii
K-1
Listed so far are:
K-S1
K-S2
K-01
K10D
GX10
GX20
K20D
K200D
K-7
K-m
K-x
K2000
K-r
K-30
K-50
K-500
K-5
K-5ii
K-5iis
K-3
Does this PDF exist yet? What is the method needed for the K-5 with latest firmware?
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Pentax Film SLR Discussion 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 10:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
