01-06-2019, 02:03 AM   #736
I am very sick but at some point I can actually attempt to edit using either a k-3 or k-1. I normally do my conversions with a k100d or k100d super. After editing I can verify the changes if it works. But that may be weeks... If my wife's experience repeats itself.
My best wishes to you to get well soon!
Health is so much more important than gadgets.
01-06-2019, 10:50 AM   #737
QuoteOriginally posted by beholder3 Quote
As you can see even in the K-1 there is an option "LENS ROM EDIT R/W" directly in the camera
This allows directly changing the bytes. I have not actually executed it personally, but I can say that clicking it does show the underlying edit interface (asking about address and data and if you want to read or write) on the K-1, so I do assume this still works there.
I already wrote a few posts above that I tried it (of course) on K-3 akd K-30 and it doesn't work. I can change address but it reads all bytes as zeros and if I edit something it's not saved. So there was some change in firmware that debug menu doesn't reflect. Of course the FW must be able to read EEPROM data from lenses but it's done differently in newer FW and debug menu code was not updated to match.
01-06-2019, 11:17 AM   #738
UncleVanya's Avatar
QuoteOriginally posted by RayeR Quote
I also missed that you had tried directly editing vs downloading the file to SD.
01-06-2019, 12:28 PM   #739
The same for [lens - body communication test] menu item. It just hangs the camera with black screen. So the routines that communicate with lens (including EEPROM R/W) was changed some way. Only chance would be to search and compare old FW that has this function working with newer FW that doesn't work. Good candidate would be K10D where one can compare FW 1.31 with some older version. But it may not be easy to reimplement it to work again.
01-06-2019, 11:27 PM   #740
I disassembled my DA 17-70mm f/4 AL [IF] SDM lens that have damaged SDM also to check if there is an EEPROM chip. I carefully looked at all chips but there is not common serial EEPROM. There is TI MSP430F1232 16-bit MCU with embedded 8,25 kB flashROM. So it may hold lens data inside. So it would not be such easy to read/write it as serial EEPROM.
Here is photo of the PCB
http://rayer.g6.cz/hardware/pentax.k30/da1770c.jpg
I'd also ask for help technical skilled users who own the same lens DA 17-70mm f/4 AL [IF] SDM to help me identify the value of blown resistor
(pointed by arrow) on bottom side of PCB.
http://rayer.g6.cz/hardware/pentax.k30/da1770d.jpg
It's not hard to disassemble (~10min) and there are step by step instructions
The chip list (most of them are tiny SMD parts with a short code hard to be identified. The big NEC chip seems to be something custom, google's silent):
top side:
TI M430F1232 17TG4 (TSSOP28, 16-bit MCU 8kB+256B FlashROM, 256B RAM, 10-bit ADC)
MF1 405 (micro SOT23-5)
bottom side:
B1AV (SOT23-5, near motor pins)
2* fairchild BHAA WZ08 (micro TSSOP8)
fairchild PB0AA LCX74 (DQFN14, 7474 dual D-type positive edge-triggered flip-flop 3,3V)
Z86F (micro SOT23-5)
Z16B (micro SOT23-5)
5W55 (micro TSSOP8)
5W56 (micro TSSOP8)
T6E5 (SOT23-5)
162Y (SOT23-5)
lens body FPC:
NEC LIC092 118M1 (TQFP48)
58C 171 (TSSOP8)
01-07-2019, 02:23 AM   #741
Some people have downloaded the lens rom settings from that lens. Maybe you take a look at those files.
01-07-2019, 07:21 AM   #742
so firmware hacking still a fantasy?
01-07-2019, 07:41 AM   #743
UncleVanya's Avatar
QuoteOriginally posted by KoolKool Quote
Can you be more specific? There's a k-50 image setup to deploy onto k-30...
01-07-2019, 09:22 PM   #744
Hi, please do you have a link for lens EE dumps?
01-07-2019, 09:41 PM   #745
well...that just a trick,can't be called hacking
i still desire for some specific hacking like
- unlock real SR for video mode, and increase bit rate as well
- for my k70 - unlock PDAF on live view shooting mode (because it's only available on video mode)
01-09-2019, 10:20 AM   #746
The first link in this thread: Datenbank für Lensroms / eeprom / Lenseep ? Pentaxians shows a link to a dropbox.
01-11-2019, 08:53 PM   #747
Thank you for the link, I had to register.
01-11-2019, 09:27 PM   #748
ZombieArmy's Avatar
These are the main things I'd loooove to see. I really wish I was skilled enough to get involved.
6 Days Ago   #749
Debug Mode for K-1 II
QuoteOriginally posted by bootcoder Quote
For K-1 to enter Debug Mode ...
  1. File 00077970.562 should contain [OPEN_DEBUG_MENU] and LF char.
  2. File DEVELOP.MOD must be exact 10 bytes long and its content should be entered in file hexeditor:
    EITHER hex bytes: 07 01 2C 1F 10 03 1E 16 05 2D enables Development Menu 1-6
    OR hex bytes: 07 1A 02 0A 19 18 1B 1C 05 11 enables Development Menu 1-7
Then turn off camera, plugin this SD card. Leave card door open. Hold "menu" button and turn camera on.
Tried that on my K-1 II - with door open and holding the Menu button: When then turning it on, the display remains black, same as if I had no files on the SD card. Tried both hex sequences. (And yes, I know how to use a hex editor, I wrote more than one myself )
I guess the file names (and/or hex codes) have changed for the K-1 II again. Anyone know them?
4 Days Ago   #750
QuoteOriginally posted by tempelorg Quote
What means "again"? Names are sure unique for each model, but stay same for each firmware of this model. This post was only for K-1 and you have different camera model.
QuoteOriginally posted by tempelorg:
Anyone know them?
Yes.
bit, camera, card, chdk, code, data, debug, dslr, file, firmware, flash, fp, gps, instruction, k-30, k-50, k30, love, magic, module, notes, pentax, photography, pin, pins, sd, text
NY area SDM Hacking dappercorpmonkey Troubleshooting and Beginner Help 11 07-26-2013 04:15 PM
Nature Resurrecting some old images - Angry Birds! Julie Post Your Photos! 4 03-07-2013 10:41 AM
k-5 firmware hacking anyone? secateurs Pentax K-5 33 10-05-2012 03:05 PM
Hacking lens' memory plis Visitors' Center 6 11-28-2011 10:58 PM
Resurrecting a MX and Super ME LiMPiNg Pentax Film SLR Discussion 4 09-27-2011 02:55 PM
All times are GMT -7. The time now is 01:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
