Originally posted by BirdDude007 I never shoot with flash and have an indoor shoot tomorrow where flash may be allowed.
I will be shooting a K-5 with a 16~50 f2.8 lens. I will be using an AF540FGZ flash that I rented. I downloaded the manual and from what it says, it should be mostly auto matic within the rangenofn13mm~52mm digital, but no matter what I do, my images are all washed out, ya if I adjust the aperture I can dial it in, but tomorrow I wont have time to fiddle with my flash, I need it to be all auto.
the manual gives no suggestions as to what to set the camera on, so I have a few questions for those of you who have this similar set up and I gotts have answers fast(by the morning please)
1-what mode do I set the camera on? "×" mode? Or program mode,
2-ISO speed?
3-shutter speed?
4-f stop?
What settings work best for you folks, the kind wherr you wont have to worry too much about, set and forget is what im asking.
do I set the exposure compensation lower, if so how much, on tbe camera and/or flash
Thanks so very much in advance folks
Unless you want to balance flash and environmental light (you would need flash gels to match the colour temp of the flash to that of the other light sources),
1. Set it to X, your shutter speed will be fixed to the sync speed (1/180)
2. That depends on the aperture and distance, ISO80 will do in most cases. You can set a higher ISO just in case (so get the shot if ISO80 isn't enough and you don't have time to dial it up)
3. In X-mode it's fixed at 1/180, you probably won't need a faster speed indoors (and you'd have to use HSS mode). If you want to balance flash and other light sources, use M-mode and lower shutter speeds.
4. Depends on the picture you wan't (shallow or deep DOF), larger apertures may not work at very close range because the flash can't be set low enough, smaller apertures will limit your flash range.
If you still have issues (especially if you use bounce flash), try setting the flash to Auto-mode instead of p-ttl. There are some with bounce flash and p-ttl on the K-5(II), in auto mode, the flash measures the exposure itself.
If you have time, practise a little so you know your way around the basic settings.
regards
Jan
