Originally posted by weirdnjfan1 Thanks for the suggetion kitty. Are either of the Sigma or the Tarmon lens full auto? This is the reason why I like using the Pentax lens, because of the fact that I like being able to switch from manual to automatic just by flicking a switch. That's why I'm considering the lens from Pentax.
No problem. The "Pentax" version of the Sigma and Tamron lenses are fully compatible the Pentax dSLR body.
You can switch between manual and auto focus using the same switch.
These are 3rd party lenses and there may be slight differences in exposure metering to what you are used to for Pentax made lenses. You get used to it after a while.
Ah, the lenses are a bit soft between 200 mm - 300 mm at wide open aperture, but still usable. Pretty sharp at 200 mm and below, or switch to smaller aperture above 200mm.
