Show Printable Version 10 Likes Search this Thread
11-05-2014, 08:42 AM   #16
Nakedgun's Avatar
I'm having difficulty locating the PF page which had all the latest firmware updates displayed. Anyone?
Thank you.
11-15-2014, 09:13 PM   #17
Nakedgun's Avatar
After download - then what?
I've downloaded the update and it says DCIM only. Where is the "dot bin" file?
07-25-2015, 01:56 PM   #18
I updated my K-100D with no issues, but having bought a new K-50 and reading ivanvernon's experience, I think I'll just leave it the bloody hell alone!
It's just way too easy to brick one of these things!
BTW; just figured out how to look it up, and my firmware version is 1.0.0.
Have they come out with any K-50 upgrades since then?
12-10-2015, 03:50 PM   #19
mysterick's Avatar
I've tried to update K-3 both directly to camera and to SD card in computer.
Either way, none of the following happens:
Insert the update SD card (prepared in step 1) into the camera (slot 1) and close card cover.
Turn the camera power on while pressing the MENU button. "Updates the camera firmware" appears in the LCD monitor.
Ver: 1.00/1.01/1.02/1.03 /1.10 / 1.11/1.20→1.21 will be displayed. Press the four-way controller to select "Start" and press the "OK" button.
"NOW LOADING" appears on the LCD monitor and updating starts.
Please do not under any circumstances switch off the power before the update is completed.
When update is completed, the "COMPLETE" will be displayed at the left bottom of the LCD monitor, then turn the camera off.
So nothing has changed. I have done these many times on my K-10, K-7, K-5, but the K-3 it doesn't happen. Ill leave it alone I guess.
02-07-2016, 03:08 PM   #20
DavidOliver's Avatar
QuoteOriginally posted by mysterick Quote
I thought I had the same problem and spent an hour trying to get the camera to use version 1.21. My wife also tried from scratch as she's performed firmware updates on her K-5 in the past.
Then she pointed out that the firmware update is for the K-3, not the K-3 II which I have. I'm not sure why I didn't pick up on that in the first place!
04-29-2016, 11:44 AM   #21
I have a video for updating K3 to 1.21. Texts are in spanish but is well understood.
Hope it helps !!
09-19-2016, 02:40 PM   #22
E-man's Avatar
I'm three for four in firmware upgrades. My first attempt was an abject failure with an *ist DL about four years ago. I was glad I had bought a Square Trade warranty when I got the camera. I sent them the camera body, kept the lens and other accessories, and they reimbursed me for the full purchase price. I was understandably skittish about firmware updates after that but then I got a KX about a year ago and it was having a problem that needed a firmware update to correct and after a lot of deliberation, I screwed up the courage to do it, slapped in a fresh set of Energizer Lithium batteries successfully updated it. That emboldened me to try and update my K100D so it would read SDHC cards and my K2000 just because I could. Both were successful.
Recently, I acquired a K10D that shows firmware version 1.0 and I'm experiencing update angst all over again. I've downloaded the update but now I'm just trying to assess the risk vs. the rewards.
11-16-2016, 04:40 AM   #23
JASMAZ77's Avatar
It looks like the last firmware update for the K-3 was 27th May 2015 surely this can't be right?
11-16-2016, 09:20 AM   #24
ivanvernon's Avatar
Bricking with firmware
Following every instruction exactly to the letter, I still bricked my K-5II and had to pay big bucks to bring the camera back to life, so no more firmware updates for me! Are there any reputable repair shops that will upgrade firmware and take the risk for themselves?
11-16-2016, 11:31 AM   #25
Otis Memorial Pentaxian
clackers's Avatar
I've never had a problem. About the only thing that can go wrong is an interruption, so I always make sure a freshly charged battery (no matter the level indicated when first turned on) is inserted.
12-11-2017, 03:56 PM   #26
If I update the firmware on my K50, which I've had for a couple of years, will I notice any significant improvements? I don't want to make a mistake and cause damage to the camera.
12-14-2017, 02:02 AM   #27
Kerebron's Avatar
If you don't need any new features introduced in newer versions, you don't have to update. AFAIK there were no bugs in earlier versions. I had been using v1.00 without any problems and updated only when I bought 55-300 PLM lens - camera is still working fine. It's an easy procedure. Just use a quality memory card (it doesn't have to be fast) and fully charged battery.
12-14-2017, 08:20 AM - 1 Like   #28
Seeker of Knowledge
aslyfox's Avatar
I just did an update for my new K 3 II
I had a problem
then I reread the instructions and found i forgot a step
no problem after that correction
I had previously updated a K 5 II and a K 3.
so my advice is to read the instructions, watch the video, read the instructions and carefully follow them completely
12-14-2017, 10:15 AM - 1 Like   #29
ivanvernon's Avatar
Update K-1
I am trying to work up the courage to update firmware on K-1 as I would love to have the square format for my crop sensor lenses. I got bit bad updating K-5ii, and once bit twice shy!
12-14-2017, 03:19 PM - 1 Like   #30
clackers's Avatar
QuoteOriginally posted by ivanvernon Quote
Get back on that horse, Ivan!
camera, dslr, firmware, pentax, pentax dslr firmware, photography, updates
Pentax Flucard O-CF1 firmware update wishlist unkipunki Pentax K-3 & K-3 II 28 10-20-2014 01:06 PM
Firmware update I'd like Pentax to implement tom1803 Pentax DSLR Discussion 12 03-12-2014 04:12 PM
Pentax K-5 II Problem after Firmware Update Deedee Pentax K-5 & K-5 II 13 08-12-2013 04:58 PM
Pentax Kr after latest firmware update jbarry Pentax K-r 3 04-06-2013 06:53 AM
Pentax Q Firmware Update Unregistered User Pentax Q 24 04-04-2013 12:24 AM
All times are GMT -7. The time now is 06:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
