02-07-2014, 10:33 AM   #1
Wired's Avatar
grip and A.S. tripod mounts
I've never been a battery grip shooter until I bought my D600 and gripped it because I felt it needed the grip to be comfortable for me. I was going to get a K5 grip but waited for the K3 to come out. Now I'm planning on getting grips for both my K3 and D800 as I loved the ease of portrait shooting with the grip. not to mention the added stability.
The problem is, I also like to have quick access to mount up to my tripods. Because I got small hands/short finger and the battery grips are typically thicker than the main grip of the camera I'm pretty much at my maximum dexterity already. So adding the tripod mount to the grip would pretty much ruin my ability to hold the camera, not to mention probably be very uncomfortable.
Is there a solution that puts a bracket on the "left" side of the camera where the audio/usb doors are at that would allow me to fasten a tripod plate onto? Or do I just got to man up and go through the minor inconvenience of screwing the plates on and off when I need them.
02-07-2014, 12:40 PM   #2
Bonobo's Avatar
I'm with you. I used to shoot with a camdapter hand strap and tripod QR plate but once I got the grip I didn't like the ergonomics as much. I haven't found a good solution yet, but I want to know what others have come up with. I've gone without for a few weeks and I think I'm going to try it on again to see how it feels.
02-07-2014, 01:11 PM   #3
I think the best solution may be to go with one of the few remaining tripod heads without QR.
QR systems make so many assumptions - and bad ones. You have only one camera, or only one tripod (or at least only one type/brand/mount of tripod heads). You never attach anything else to the tripod mount on the bottom of your camera (like a speed strap or other accessories). You never like to place your camera on a flat surface, whether just setting it down or using the surface as a quick, temporary "tripod." You actually like having QR plates attached to all of your cameras. The 5 seconds you may save using the QR matter more than the many minutes you'll wasted because of all the other hassles QR causes you.
I have a well-designed non-QR mechanism on a Velbon Pan/Tilt head and it's very quick to take the camera on and off. Besides, Tripod shooting takes time to set up properly. If speed is really of the essence, you leave a still or video camera attached for most or all of the session/event. If you're taking it on and off, it inherently means you have a little time to spare - 5 seconds shouldn't make or break it.
QR allows you virtually no variety in the selection of cameras and tripods you will have. It's insane.
Having said that, I still have some tripods with QR because I can't, or have been too cheap to, replace the QR heads. But I hate it.
02-07-2014, 02:38 PM   #4
JimmyDranox's Avatar
I have an Arca Swiss L plate permanently on my camera, over the vertical grip. But I have big hands. and the extra dimensions (10mm in thickness), don't bother me much. But for someone with small hands, is a problem.
Also a problem is the number of Arca Swiss clamps that I have to buy, to change all the mounting plates of my 2 tripods, and the movie rig. I have an Velbon with Pan/Tilt mechanism ( which is not good, because, after some time, the pan/tilt became unstable, whatever I do, so 'Ive change it with a ball head), and my new Fancier video fluid head tripod, which has a different size plate. Fancier has a plate that's looks similar with Arca Swiss, but it's not a 38mm V plate, but something like V 42-43mm plate. Not to mention that the Arca Swiss L plate is side-by-side oriented, along to the camera body, while the tripod clamp is front-back oriented. Finally, with almost 100 euros, and a lot of patience, I have a full system with Arca Swiss. For Camera, two telelenses which has tripods atachments, and everything. And is quick and safe to use. But it's not a solution for you.
Maybe, a custom L plate, of half thickness of a regular Arca Swiss plate, because the active part of this kind of plate is only 5mm, could be good for you. Maybe.
02-07-2014, 02:48 PM   #5
Wired's Avatar
it's too bad there is no ultra thin, but durable, L-plate that can slip between the grip and body without interfering with the required connections that puts a tripod mount in my desired location... seems like all the L mounts I can find mount to the side of the camera.
02-07-2014, 07:24 PM   #6
Canada_Rockies's Avatar
QuoteOriginally posted by Wired Quote
I think that would be difficult to engineer, and still retain the WR of the grip/camera combination.
02-08-2014, 12:52 AM   #7
It would be nice if they made a grip that was compatible with tripods like Fuji is doing.
battery, camera, dslr, grip, grips, k3, photography, tripod
Modding Chinese (and other) tripod mounts to fit eg adaptall lenses marcusBMG Maintenance and Repair Articles 19 12-30-2020 04:22 PM
DIY: Tripod Mounts using Leg protector and Shoulder Strap raider Do-It-Yourself 20 01-09-2012 08:53 PM
Tripod mounts littledrawe Pentax SLR Lens Discussion 3 10-18-2011 12:16 PM
what's the difference between a cam tripod and umbrella/flash tripod? mike.hiran Flashes, Lighting, and Studio 11 06-23-2009 06:56 PM
For Sale - Sold: Amvona AT-6703 tripod and pistol grip head. pcarfan Sold Items 14 02-16-2009 06:56 PM
All times are GMT -7. The time now is 10:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
