02-11-2014, 08:02 PM   #1
Continuous Shooting, Exposure Bracketing, Interval Shooting etc in B Mode!
Hi all,
What do you think if K5 series and K3 can set to Exposure Bracketing, Multi-exposure,
Interval Shooting, or Interval Composite in Bulb mode?
Reason to allow all these functions in Bulb mode is to make Long Exposure bracketing ( more than 1 minute), timelapse and nightscape photography easier.
Hope Pentax Ricoh can consider to allow those great functions in Bulb Mode.
Tommy
02-11-2014, 08:18 PM   #2
How would any of that work in bulb mode?
02-11-2014, 08:28 PM   #3
QuoteOriginally posted by elliott Quote
Doing more than 1 minute interval composite with the help of timer remote in B mode, or nightscape timelapse in B mode since we can set the interval from 2 seconds to 24 hours.
02-11-2014, 09:01 PM   #4
The contradiction I'm seeing here is bulb is an extremely simple mode, you press the button when you want to open the shutter, release it when you want to close it. Most of what you are talking about requires the camera to control the shutter, with the exception of multi-exposure which I believe you can already do in bulb mode.
If you're using an external timer I don't see anything stopping you from doing the rest of what you mention.
02-11-2014, 09:07 PM   #5
My question is how come Pentax Ricoh never allow them in Bulb mode in the first place? Any reason? Thanks.
02-11-2014, 09:29 PM   #6
I can't understand how it would work and make sense. Except for multi-exposure they require the camera to control the timing of the shutter, which is exactly the opposite of what bulb mode was created for and does. Bulb mode and multi-exposure makes sense, I can do that with the K-5 without a problem.
Maybe you could take me through the process you envision to use these features in bulb mode. Does some other camera do this?
02-11-2014, 09:59 PM   #7
sterretje's Avatar
Because they have not seen a need for it.
Yes, it can be implemented; your camera can time the first bulb exposure and automatically adjust the next ones based on that time (e.g. halving and doubling the time (exposure bracketing) or repeating all successive shots with the same time (multiple exposures / interval shooting)).
02-11-2014, 10:47 PM   #8
kiwi_jono's Avatar
I often think that its a pity that extended exposure times are not available in Manual mode. It would be great if you could set 1, 2, 5, 10 minutes at least (noise is good at 10 minutes on these modern DSLRs)..
02-12-2014, 01:45 PM   #9
You can achieve a result very similar to extra long exposure times by using multiple exposure mode with the slowest shutter speed of 30 seconds.
Set the shooting mode to interval composite the interval to 32 or perhaps 33 seconds and the combining mode to average or additive depending on what you want to achieve.
You can set the count up to 9999 shots which would give you an effective exposure time of up to almost 4 days.
You would typically use average if 30 seconds is enough in terms of illumination or additive if 30 seconds is too little for correctly exposing each frame.
There will of course be short gaps in the exposure, so something like star trails might not work out that well. However for most other situations it gives you results that are not just equivalent to but considerably better than what you would get with a 'real' long exposure.
camera, dslr, exposure, interval, mode, photography
K2000. Undable to enable continuous shooting or raw mode michael772 Troubleshooting and Beginner Help 3 11-02-2013 02:55 PM
continuous shooting mode Preston Pentax K-5 23 09-27-2011 04:58 AM
K-7: Interval Shooting with bracketing - is it possible? Northern Soul Pentax DSLR Discussion 5 09-21-2011 09:42 PM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
auto-bracketing continuous shooting AlexTiShark Pentax DSLR Discussion 12 09-15-2007 08:20 PM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
