04-14-2008, 03:50 PM   #1
Green button and old lens
Hello,
I am a beginner and i have picked up a SMC-M 50mm f1.7 about three weeks ago. I love this lens and i haven't touched my only other lens (the kit lens) since.
I have a GX-10 and it has, as far as i can tell, the same exposure issues as the K10D. Using the green button, it underexposes from wide open until about f4, it's ok until f5.6, and it overexposes from there on.
That is true in normal lighting situations, but for some reason, when it get dark, it underexposes at all aperture. Actually, i feel like it is not possible to get anything above 1''6.
This is a big problem for night photography since i need to pretty much guess. I am getting quite efficient at this little game, but is there something easy i can do about that?
04-14-2008, 10:28 PM   #2
Canada_Rockies's Avatar
QuoteOriginally posted by deudeu Quote
Hello,
Try using the depth of field stop down feature on the power switch and using the +/- scale to set the exposure. I had to test my M 400/5.6 and find that if I metered at f/8, it gave me the base exposure correctly. Also, if for night exposure, you are away from the eyepiece, then the light coming in through the eye piece can throw the exposure off. Hold your thumb over the eyepiece while you push the green button and see if that helps - assuming that you do not have your eye to the eye piece for these exposures.
04-15-2008, 12:44 AM   #3
pschlute's Avatar
Well documented problem with the K10. Fit a new focus screen .. an L80 or one from a Pentax DS. Cures the problem.
04-15-2008, 09:43 AM   #4
QuoteOriginally posted by Canada_Rockies Quote
I will try it out, though i have a hard time understanding how the light going through the viewfinder would mess up the exposure at night.
I have been working with stop down feature as well. I like it almost better than the green button. It is just a little tough when using spot metering.
I know the exposure problem is well documented. I just haven't found anything about constant underxposure at night.
I was out yesterday night taking pictures again and the green button underexposes At all apertures, all the time.
button, camera, dslr, lens, photography, underexposes
Green Button Metering with Manual Lens zombieCat Pentax DSLR Discussion 4 02-15-2010 06:07 AM
SR and green button slow2focus Troubleshooting and Beginner Help 7 12-12-2009 11:56 AM
m42 lens + Pentax AF 1.7 TC + Green button Sudhakar Pentax SLR Lens Discussion 0 10-08-2009 11:06 PM
That Green Button - Useful! photog Pentax DSLR Discussion 0 07-03-2009 02:07 AM
K10D and Green Button Manual Lens Shutter Speed David Pentax DSLR Discussion 4 10-15-2007 12:41 AM
All times are GMT -7. The time now is 10:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
