04-15-2008, 04:54 PM   #1
AF Area Test in K10D Debug Mode
Hi guys,
I've just received my DA* 16-50 3 days ago. Initial testing on my K10D shows that it BF quite a bit at the wide end. So I decided to downgrade my firmware from 1.3 to 1.1 just to adjust the AF.
In the Debug mode, AF Test menu, there are AF Area Test and Focus Corr. I used AF Area Test =0 and Focus Corr = +40 to correct my BF issues. Since AF area test has values from 0-3, it got me thinking.... maybe thats for 4 lens? or 4 focus area?
I have read in various forum post that Pentax service center can store up to 4 lens AF adjustment on the K10D. Then the AF area test has 4 values too. Maybe they are the same thing?
I also realise K100D debug menu also has 4 values for the AF area test.
Anyone has any experience?
Mike
05-28-2008, 10:03 PM   #2
Kentax's Avatar
very interested in this as well. anyone care to chime in?tia
05-29-2008, 12:18 AM   #3
rant/ There have been numerous threads on this topic in the Forums. Use of the "Search" feature would come in handy before adding new posts when dealing with "how to" questions, as you'd probably get your solutions much sooner that way. /rant
OK, now for the (hopefully) helpful part:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/3158-k10d-service-menu-af-adjust.html
https://www.pentaxforums.com/forums/pentax-dslr-discussion/18498-two-ways-adjust-focus.html (start at post #6)
and, just in case you need to go back to firmware v. 1.1 to get access to the debug menu: https://www.pentaxforums.com/forums/pentax-dslr-discussion/25001-k10d-so-debu...adjust-af.html
Lotsa luck with your focus tweaks!
05-29-2008, 08:30 AM   #4
joefru's Avatar
But I thought the Russians figured out 1.3 debug...
05-29-2008, 08:55 AM   #5
QuoteOriginally posted by joefru Quote
he he he he!
good one!
05-29-2008, 01:53 PM   #6
Kentax's Avatar
QuoteOriginally posted by mcjm78 Quote
Mike
wow, those links were a complete waste of my time clicking. I've read them repeatedly prior to your "help" and none answered the question above.
05-29-2008, 01:58 PM   #7
vizjerei's Avatar
Debug mode AF area test explained!: Pentax SLR Talk Forum: Digital Photography Review
Here you go, info about AF Test Area.
05-29-2008, 05:19 PM   #8
Kentax's Avatar
QuoteOriginally posted by vizjerei Quote
terrific. thanks for your help, again!
05-29-2008, 08:58 PM   #9
vizjerei's Avatar
But I want to know what the other things in the Debug Menu do...
06-26-2008, 11:01 AM   #10
This thing really works! I've been completely frustrated with the AF on my 77 and 31mm ltd primes. Now they focus perfectly even at 1.8 Needless to say this was a great thing...thanks to those responsible for writing this program.
BTW- my DA lenses are focusing better as well.
12-11-2010, 04:30 AM   #11
DontKnowler's Avatar
There is no need to use a special program or to downgrade firmware in order to enter the debug mode on k10d. It is enough to place a text file MODSET.txt containing only one line of text [OPEN_DEBUG_MENU] in the root of your SD card. Donīt forget to place a line break in the end of this line, or it will not work.
02-07-2011, 09:57 AM   #12
K10D Firmware 1.31 debug mode to rectify back/front focusing
After some Googling, I've found this excellent and simple method by Ivan Glisin:
No need for 1.30. Do the following with 1.31:
In the root directory of your memory card create or copy a text file named
MODSET.TXT
with only one line in it:
[OPEN_DEBUG_MENU]
After inserting card back to the camera, to enable debug mode do the following:
1. Switch camera off.
2. Open card door and leave it open.
3. Switch camera on -- debug menu shows up.
4. Close card door.
5. Left/right to enable debug mode.
6. Press OK to confirm.
7. Go to Set-Up menu, go to the end and Set-up will change to TEST MODE menu, AF TEST option is there with Focus Corr inside.
To disable debug mode:
4. Close card door.
5. Left/right to disable debug mode.
6. Press OK.
Note: you can permanently leave MODSET.TXT file on your card.
Read more at: https://www.pentaxforums.com/forums/pentax-dslr-discussion/128474-need-k10d-f...#ixzz1DHfb0nZE
af, camera, debug, dslr, focus, k10d, lens, photography, test, values
K10D focus adjustment with debug mode cem.kumuk Pentax DSLR Discussion 12 01-16-2016 07:11 PM
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
Debug Mode Question about "AF Test Area" values brecklundin Pentax DSLR Discussion 1 06-16-2010 04:46 PM
K10D debug mode and 35 Limited macro treebeard Pentax DSLR Discussion 10 10-21-2009 08:47 PM
K10D doesn't trigger shutter after debug mode Marcoz Pentax DSLR Discussion 7 02-18-2009 11:27 AM
All times are GMT -7. The time now is 08:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
