Hello,
Previous K-5 user. I am currently a m43 user.
Recently I used a friend's K100D (not Super) body. While I didn't like the viewfinder and general responsiveness of the body (maybe it had to to with the bad-looking after on the body) I was impressed with the colors and the 1600 iso clarity. Here are few examples I took with the body. The images were made with a Pentax A 50mm f/1.2. These are just for giving the camera + lens combo a go, nothing artsy or technical;
These are all shot at ISO1600-f/1.4-1/160 (the kit lens is 1/15) under dim-ish light. I overexposed these shots by +0.3EV (or maybe +0.7, not sure) and then in photoshop I slightly pulled the bright areas and moderately darkened the shadow areas. This method is supposed to yield clear high ISO images in any camera, but I still didn't expect the K100D to provide such clean images. There is some selective sharpening and contrast on the images too. A very very mild amount of NR applied.
The 6MP sensor of the K100D might have something to do with the high ISO too. Seeing this I am thinking of getting a cheap used Pentax body which will not irritate my wallet. Since I will be using it with the only Pentax lens I have, which is a manual lens, I think a K10D with a pentaprism would suit me better with its brighter VF. But since the K10D is 10MP I am not sure about the high ISO performance. But it has more pixels than the K100D and that could be a positive factor too, since size reduction greatly takes care of the noise.
So how will the K10D yield in this process? Or would you recommend me another body?
Any information will be appreciated. Thank you.
