01-22-2007, 09:52 PM   #1
Sensor cleaning
I got my K100d by Christmas, today I was trying to clean the CCD, so I enter to menu to choose sensor cleaning and select "mirror UP", and after I press "OK" the screen show Battery depleted", and turned off automaticlly, then I chaged to Alkaline battery and the problem was the same..
I'm using energizer rechargeble NiMh 2200mAh, and the battery was fully charged... so can somebody solve my problem?
01-22-2007, 09:56 PM   #2
I don't know if the planets are in the wrong alingment or what, but I can't get NiMh battery to hold a charge for anything right now. I just threw away about 20 of them because I would get just a few shots and they would die. Different brands, different mAh, different age. All bad in the last few weeks. Something is in the air.
01-22-2007, 10:28 PM   #3
QuoteOriginally posted by davemdsn Quote
Probably not, but it does seem like there maybe something in the charger! Do have it checked out by a competent technician as a starting point. Presuming that you're using them in a camera, if the charger is not the problem then either the camera has problems or it's a case of operator error.
These batteries are normally super reliable when used correctly.
01-22-2007, 10:35 PM   #4
-=JoN=-'s Avatar
have you updated your firmware lately? not sure if it was an issue with earlier firmwares for that body. the k10 had a problem when in bulb mode. it would report low battery. was fixed in the new firmware
just a thought
01-22-2007, 10:52 PM   #5
jfdavis58's Avatar
The K100 also uses the painfully expensive crv3 batteries; but they have an excellent shelf life. Sensor cleaning and firmware updating are semi-critical and critical activities; find some crv3 on sale and keep a set in your bag. Sorry for the 'in-your-face' attitude of my answer, but...
The other safe alternative is an external power source and being tethered to the wall outlet for these operations. The flip side is to keep using undependable rechargeables in critical activities, locking up the camera or botching the firmware and a trip to a service center for even more expensive non-warrantee repairs.
01-22-2007, 11:45 PM   #6
Multiple chargers, multiple cameras. I think they are just mad because I spend more time with the K10.
01-23-2007, 06:31 PM   #7
Alvin's Avatar
No, they are just saying, "put us out of our misery!" j/k.
To be honest with you, no clue why your batteries are giving you such a hassle but I did a firmware upgrade about a week before I tried to invade my camera to blow out some dust. No problems. Are you at the latest firmware?
01-24-2007, 07:58 AM   #8
Thanks to everybody.. my problem is solved..
how? just updating the firmware..
01-24-2007, 04:52 PM   #9
roy
roy's Avatar
why not spend $10 on an external power sourse. you might even have a wart laying around that's 6.5 volts. i don't use a card reader to d/l images so i've got a multi voltage ac/dc converter. works great with my DS at 6.5v and my fuji at 5/.5v.
01-24-2007, 05:00 PM   #10
roy
roy's Avatar
also, when the sensor really gets dirty(100% chance) you'll need to visit these guys
Micro-Tools, Camera & Watch Repair Tools - Sensor Cleaning Items
and purchase this
https://www.micro-tools.com/store/item_detail.aspx?ItemCode=DIGI-KIT4-F
they have an excellent tutorial about sensor cleaning on their site.
01-25-2007, 09:52 PM   #11
chedoy's Avatar
My Eclipse solution and Pec Pads arrived today so I was finally able to wet clean my K100D sensor.
It had a lot of dust that wouldn't blow off. Dozens of specks including some large oieces of lint there were stuck. So being impatient, I tried some tape. The Scotch Magic Mending Tape had been billed as effective and it did work well on the first try, but I couldn't leave it alone and when I did it a third time, it left adhesive on the sensor. I say don't use tape.
I wrapped the Pec Pads around a piece of stiff cardboard with a rubber band, wetted them with the alcohol solution, and after some swabbing, the goop came off. It wasn't that trivial and I was afraid it wouldn't work but the sensor eventually came clean. I still see two or three small specks on a test exposure, but I can deal with them.
You might be able to buy Ecipse solution and Pec Pads at your local store. I originally asked for a sensor cleaning kit, but Ritz/Wolf didn't carry a kit. They probably had Eclipse and lint free wipes though.
01-26-2007, 07:25 AM   #12
roy
roy's Avatar
i've seen the use tape suggestion before, no way i'd use it..
i did try a brand new lenspen.. forget it, it left 300% more on the sensor. i'll stick(?) with the pecpads .....
01-26-2007, 08:58 PM   #13
SpecialK's Avatar
QuoteOriginally posted by roy Quote
and purchase this
I just got that kit (actually the "bigger" one that includes the Rocket blower). It seems to work well, though I will find out tomorrow for sure. I'm having to re-arrange my bag to hold that blower, much less the other parts :-)
01-26-2007, 09:20 PM   #14
After reading a few sites about dust I went out and bought a rocket blower also. I'm sure ill need to use it at some stage.
battery, camera, dslr, photography, sensor
Cleaning a K-X Sensor..... How? Silverkarn Pentax DSLR Discussion 17 09-15-2010 09:08 AM
Sensor cleaning. Modus Operandi Troubleshooting and Beginner Help 17 03-12-2010 04:48 PM
Inspection after sensor cleaning? niklas Troubleshooting and Beginner Help 5 10-02-2009 08:42 PM
Sensor cleaning: Pec-Pads or Sensor Swabs gadgetnu Pentax Camera and Field Accessories 29 09-24-2007 10:52 AM
Sensor cleaning > Sensor Swab > void warranty? Twinky Pentax DSLR Discussion 2 07-28-2007 01:10 AM
All times are GMT -7. The time now is 08:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
