03-03-2014, 09:26 PM   #1
Bmer's Avatar
DLSR's vs. Strong Magnets
Working on a backpack tripod system (Prototype #2) and was wondering if anyone knows for sure.
Do strong magnetic fields have an adverse / permanent effect on the various electronics in DLSR's ?
Trying to keep things ultralight and thinking of using some super magnets to hold thing together.
Any and all input from you folks out there appreciated in advance.
Stan Locke
03-03-2014, 09:51 PM   #2
No they dont
03-03-2014, 11:02 PM   #3
dms
But backpacking your compass will have a problem. Even the shaping magnet in selenium light meter reversed the polarity in my compass.
03-04-2014, 04:48 PM   #4
---------- Post added 03-04-14 at 06:49 PM ----------
QuoteOriginally posted by dms Quote
Ah but a photographer can tell true north without a compass..It's the biggest best natural soft box you can get.
03-04-2014, 05:54 PM   #5
...strong enough magnets to hold your camera on a tripod might be strong enough to cause mechanical problems.
03-04-2014, 09:25 PM   #6
sterretje's Avatar
Your electronics will more than likely be fine. The mechanical parts will be another story. How bad it can get, I can't say.
03-04-2014, 09:30 PM   #7
crewl1's Avatar
The floating sensor shake reduction works on electromagnets I believe. That would pretty much get trashed no ?
Another brand may be OK.
03-04-2014, 09:36 PM   #8
MadMathMind's Avatar
As long as everything is turned off, it should be fine. Otherwise, anything with electrical circuits doesn't play well with strong magnets. A strong magnetic field will mess with inductors, which will make things go wonky. It's unlikely you'll damage anything (unless the field is so strong it induces additional current that fries chips), though. Take the device out of the magnetic field and it should go back to normal instantly.
You won't be able to magnetize any of the metal components in the camera permanently without one hell of a magnet and a lot of force, so no worries there. Plus, magnesium is not ferromagnetic.
03-04-2014, 10:06 PM   #9
What material is the frame going to be made out of?
To get magnets to work you will have to build the system out of ferrous metal. I think most ferrous metals will be heavier than aluminum or plastics.
You may want to use aluminium tubing or T slot framing for your frame and use a different type of connector. Aluminium Clamp-On Framing Fittings or something like that. Lots of options out there for framing systems.
Maybe even plastics, you can get nylon screws and fittings that will fit the cameras tripod threads.
Just a thought...
03-04-2014, 10:16 PM   #10
If you open up the camera drop a magnet inside it and put the lens back on it and then do vigorous hiking it will likely damage your camera.
Otherwise it will not harm your camera in any way.
03-04-2014, 10:58 PM   #11
QuoteOriginally posted by Bmer Quote
Strong Magnets
Camera might get invisible under strong magnetic field If that does not happen then you might see color distortion on the LCD and blurry picture due to unreliable SShift.
03-05-2014, 01:42 AM   #12
AquaDome's Avatar
The little super-magnets that are used in closures will not harm your camera in any way.
Their super-magnetic property is caused by them not projecting their magnetic lines of flux outwardly. Instead, the field of flux is all very close to the magnet, which is why they stick to each other so well.
It might still screw with a compass though.
03-05-2014, 09:40 AM   #13
Lowell Goudge's Avatar
Not to hijack the thread, but magnets of the strength you are discussing can also cause problems if close enough to cardiac pacemakers and other medical implants
03-05-2014, 01:23 PM   #14
Not sure how strong the magnets are, maybe a super-strong one should affect the SR system?
03-05-2014, 09:52 PM   #15
Bmer's Avatar
My biggest concern is it may affect the SR system.
Won't be using any magnets to hold the camera is place (Have a lightweight Sunwayfoto FB28 ballhead and their panning clamp ) but for holding the
leg assemblies together while they're packed up.
Will try post some photo's of the 1st prototype soon.
Uses my 2 hiking poles and a 3 section Easton alum. tent pole which I which I need and carry anyway.
Happy with the stability and it's less that 200 grams without the ballhead
but lengthy set time and a couple design flaws I didn't catch until it was too late have me working on design #2.
Thanks for all your input folks.
box, camera, compass, dslr, magnets, photographer, photography
46MP's vs. 36 vs.16.3(latter two w/no AA filter)... tabl10s Pentax K-5 3 11-18-2012 12:20 AM
Camera comparison: One X vs Galaxy S II vs Nexus vs N8 vs iPhone 4S jogiba Non-Pentax Cameras: Canon, Nikon, etc. 3 04-12-2012 07:41 AM
DA WR lenses dust magnets? future_retro Pentax SLR Lens Discussion 6 07-17-2010 09:32 PM
K7 vs. Kx vs. K20D vs. K10D etc .. what's going on? Bashing revisited. jpzk Pentax DSLR Discussion 37 02-08-2010 07:55 PM
please critique my work. what's strong, what's weak? konraDarnok Post Your Photos! 2 11-02-2007 02:53 PM
All times are GMT -7. The time now is 11:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
