03-08-2014, 07:54 PM   #1
Firmware update I'd like Pentax to implement
I would like Pentax to implement a feature that would allow the camera to wake up from sleep mode when you press the AF button on the back.
Too many times I have missed a shot because the camera was in sleep mode and I have to half press the shutter button to wake it, then press AF and then press the shutter again to take the shot.
I know this problem exists only if you use the back AF button to acquire focus.
What are your thoughts?
03-08-2014, 08:10 PM   #2
VisualDarkness's Avatar
It's a stupid design I agree, nice point! This should be sent to Pentax/Ricoh.
03-08-2014, 08:52 PM   #3
bgdisc's Avatar
I've gotten use to half pressing to wake up the camera, but it would be useful if it would wake up with the rear af button as well. What I'd like them to add is toggling of any drive mode setting with either the green button or the RAW/FX button. Right now you can set the RAW/FX button to enable bracketing, but then to disable you have to go back into the drive modes and change it. I want to be able to press it again and go back to whatever my previous drive mode was.
03-08-2014, 09:14 PM   #4
While we're at it, I would also like them to add a User Menu where you can place your most often used menu settings. For example, I find the "Format" function too deeply embedded in the menu. This is one of very often used function, so I would love to be able to place this on my User Menu for quick access and have this menu as the default first screen when menu button is pressed.
03-08-2014, 09:17 PM   #5
Canada_Rockies's Avatar
My K10D wakes up with the AF button. I just tried it.
03-08-2014, 09:48 PM   #6
SpecialK's Avatar
QuoteOriginally posted by bgdisc Quote
I wanted that, too. Silly.
QuoteOriginally posted by tom1803 Quote
...I find the "Format" function too deeply embedded in the menu.
Luckily that is usually my sticky last-used menu setting :-)
03-08-2014, 09:54 PM   #7
jeffshaddix's Avatar
I have ideas too for firmware changes. How can we actually get these ideas voiced and acknowledged. @Adam any thoughts?
03-08-2014, 10:35 PM   #8
QuoteOriginally posted by Canada_Rockies Quote
Hmmm ...... Interesting.
I used to have the K10D as well, but I dropped it and it died.
I don't think I was using the AF button at that stage so I probably didn't notice.
03-09-2014, 12:38 AM   #9
geomez's Avatar
I personally have my finger half pressing the shutter button at all times while looking through the viewfinder. I do so to try and minimize whatever motion is created by pressing the shutter button. I figure less motion is created from a half press than a whole press. I'm not sure if I'm being overly precarious or if it actually makes a difference.
03-09-2014, 12:54 AM   #10
MarkJerling's Avatar
While we on firmware update "wants": How about we go from 3 user presets on my K-5 to 10? Oh, and just to be difficult, I'd like a built in "stitch" function too!
03-09-2014, 02:53 AM   #11
rod_grant's Avatar
I agree Tom.
I'm not sure that I miss too many shots, but it is annoying to press AF and see nothing happen!
<composes picture, presses AF, notes nothing happened, takes camera away from eye to check he has pressed AF button, half presses shutter to wake camera, starts composing again, wife says 'what are you doing?'...>
03-12-2014, 08:04 AM   #12
I would like this too, having just started using the back button AF technique.
03-12-2014, 04:12 PM   #13
QuoteOriginally posted by Dieseler Quote
Same. Would be a nice feature to have.
af, button, camera, dslr, mode, pentax, photography, press, shot, shutter, wake
Firmware Update - What am I doing wrong? Liney Troubleshooting and Beginner Help 20 03-07-2014 06:08 AM
Stuff I'd like to see in Q firmvare 1.11 Erich_H Pentax Q 12 11-12-2012 05:55 PM
Id like to achieve macro of the magnification in this video. How can i do it? dmbaile2 Pentax SLR Lens Discussion 14 05-16-2012 08:27 PM
I'd like to adapt a Nikon lens TO the Pentax 6x7...possible?? Corran Pentax Medium Format 6 12-13-2010 11:13 AM
Do i need to download firmware update? mab18 Pentax DSLR Discussion 3 02-09-2010 01:58 PM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
