Originally posted by larryaustin3 Your images are outstanding. I see some of them are taken with the K-01. Do you take it to sporting events as a second body? How do you like it for action shots?
It depends on where I go and how much I want to take along. So sometimes I just go and take K-5/K-3 with the DA*300mm, if I only want to cover some sports on a large field and don't be busy with things around the field. Or just the FA*85mm on a camerabody, depending the body on what to do.So for the image off the girl carried out off the stadium I only had K-01/FA*85 with me and I considder this one off my best images last year. If I do want to take some images off the surroundings, then I mostly take the K-01 with either FA31mm or FA*85mm on it depending off what I want to catch. I try not to change lenses on the venue, so I hardly take extra lenses with me, just put another camera/lens combo in my back. So last sunday for hockey final and swimcup I took K-5/DA*300, K-3/FA*85 and K-01/FA31mm with me. To be able to make a mix off images. The choice for using the K-5 with the 300mm instead off the K-3 was based up on the limiting light in the swimming arena where I have to go to iso6400. I could have changed between those two going from hockey to swimming, but I'm lazy. For serious action you can't depend on the AF in the K-01, so you need to make that your own skill.
I added some new images this month.
