Originally posted by stillshot2 When you point your K50 up to a plain bright blue sky, do you not see a textured pattern on the sky caused from the viewfinder?
I have a K10D (my friend has a K-50) and I do indeed see the texture of my aftermarket KatzEye screen when held up against the sky. The same is true for each of the dozen-plus SLRs* on my shelf. With some, the Fresnel pattern is obvious and with others it is a fine matte pattern. Which pattern depends on the age of the camera.
* Pentax, Mamiya/Sekor, Ricoh, and Minolta dating back to the mid-1960s through the mid-1980s. I also have an Olympus OM screen that I use for rangefinder calibration on my rangefinder cameras. It also is not clear.
---------- Post added 04-10-14 at 08:05 AM ----------
Originally posted by stillshot2 That being said I may invest in a viewfinder magnifier to hopefully make up for the lost clarity
That may well make the focus task easier, though I suspect that you will find that the objectionable grain is more, rather than less, prominent when magnified.
I hope you find a working solution. It is has been difficult for me to visualize your issue since you refer to the view as being both grainy and smeared. I just have to trust that what your eyes see is different than what mine might see.
To summarize the options in answer to your original question:
- There are no clear focus screens on the market, regardless of camera make. All require some mechanism to scatter light at their surface to create the visible image.
- Some available screens (e.g. Canon S-type with Super Precision Matte) have a very fine matte surface that may be less objectionable to your eyes than the screen in the K-30
- A viewfinder magnifier may make manual focus easier
- A screen having a focus aid may make manual focus easier
- If the viewfinder on another brand camera is more clear to your eyes, that camera may be a better choice than the K-30. There are no other options other than the points above for a Pentax dSLR.
Good luck and hope you are making great photos, regardless of your gear!
---------- Post added 04-10-14 at 08:10 AM ----------
Originally posted by ScooterMaxi Jim Pentax and KPS in particular
I gotta ask...What is KPS?
