I have used both the K-30 and K-50 and would not characterize either display as grainy. Part of what you are experiencing may be due to the Sony only having 0.74x magnification vs. the K-30 0.92x magnification. Translation? The viewfinder image for your K-30 is 24% larger which may mean that you are able to see the graininess that is there on the Sony, but invisible due to small size. Just a thought.
Originally posted by stillshot2 My Canon AE-1 with it's huge pentaprism a grainy effect too, but it also has a split prism focusing screen, which is why I am guessing this is a property of a focusing screen more than the actually prism or mirror?
Well, there you go. The AE-1 had about 95% frame coverage and 1:0.86 magnification making for a huge viewfinder image with a bit more magnification than the K-30. If you had complaints about graininess of the AE-1, I can see why you are seeing the same thing on the K-30. As for the split-image...yes, that is a feature that is built into the focus screen. Your K-30 will accept aftermarket screens having a similar split image (I use the Katz Eye in my K10D), but it will probably still appear grainy to you. There are trade-offs and cautions, but if you frequently use manual focus lenses and want to use the viewfinder for focus, an aftermarket screen is a strong recommendation.
