Originally posted by Dartmoor Dave
Edit: Come to think of it, I do know why the meter doesn't show permanently. There's no aperture follower on the K10D mount, so it can only meter a pre-A series lens if you physically pull the DoF preview and stop the lens down.
Huh? There is no way to implement this since metering should only happen with the lens is stopped down. I have my K10D in front of me, mounted to a Pentax-M 50/1.7. Here is the flow:
- Aperture ring enabled in menu settings
- Camera in M mode
- AF off
- Set desired aperture on lens
- Frame and focus on subject
- Press green button. Camera should set shutter speed.
- Confirm focus and release shutter
- Continue shooting until either your subject or the light changes
- or -
- First three steps as in the list above
- Set desired shutter speed on the body
- Engage optical DOF preview to stop down the lens, activate the meter, and display the meter bar in the viewfinder
- Adjust aperture on lens until the meter bar centers
- Release the DOF preview
This second sequence is essentially the same as using a 60s-era Pentax Spotmatic.
Those are the steps, though there is one HUGE gotcha. The exposure metered by the camera may be appropriate or it may not.* If the set aperture is wider than about f/4, the meter reading will result in underexposure. This may be as severe as 2+ stops at f/2 and wider. The excepted solution is to review the histogram for the first shot and adjust either aperture or shutter to provide the required compensation. Again, you need only do the metering and any compensation once per subject in a given light regime.
P.S. The e-dial assignment is not programmable for M mode on the K10D, at least not through firmware v1.20.
* Known issue with Pentax cameras later than the *ist D series up to the K-7. No there is no magic workaround. If it existed, I would be using it, believe me.
