Originally posted by ManuH I have no definitive answer for the OP's question but on the K20D you can see the effects of SR in Liveview.
Yes. And it is easy to see what is happening in panning:
The sensor is shifted as much as possible to the edge opposing the turn -- and stays there (as if there were panning mode detection). This is about 2mm shift. Because rotation is detected, the sensor cannot come off the edge.
So, when the shot is taken, the sensor is only able to move freely in one direction which minimzes blur. A good thing if the lens' image circle had this extra 2mm.
As soon as the panning stops, the sensor crawls back to center.
There may be issues with panning if it is too slow, though.
EDIT:
I may be wrong for the following reason:
Without LV, the sensor is moved by SR only at the moment an exposure is started. So, it is shifted to the edge and the photo is spoiled. My consideration may still be ok for images taken in 21 fps burst mode
