04-07-2014, 05:14 PM   #1
K5iis firmware upgrade stuck on Phase 1/3
Has anyone had this happen?
I just purchased a K5IIs and its on firmware 1.0. I tried to update it to firmware 1.07 or even earlier versions without luck. I have a K5 and know how to perform the upgrade correctly. I even reset the camera.
The issue was the first time I tried, the camera went into phase 1/3 and for a mere second or two and stopped. It brought me to the regular camera menu, but ver 1.0 was still the firmware.
I tried a few times more to effect the upgrade and each time, it's stuck on Phase 1/3, even for several minutes. Thankfully I can pull the battery and it still works.
Would should I do? Is there a way around this or is the camera defective?
Thanks!
04-07-2014, 05:47 PM   #2
QuoteOriginally posted by twitch Quote
Are you sure you've downloaded the right firmware for your camera model?
Hi Twitch. I am 100% positive they are the correct files since the file names are k5_2s107.zip, etc. I downloaded again to be sure. Thanks
04-07-2014, 06:07 PM   #3
QuoteOriginally posted by rfaucher Quote
Thanks!
This might be a longshot, but is the SD card locked perhaps? IDK if the camera needs to have write access during the update. Also, try formatting the card in-camera.
04-07-2014, 06:51 PM   #4
Thanks Adam. SD card is not locked and I tried two other SD cards with the exact same result: stuck on Phase 1/3.
04-07-2014, 07:20 PM   #5
calsan's Avatar
I would stop trying to update the firmware. If it fails, then you've got yourself a brick.
Did you buy it from a brick and mortar store? If so, go there and ask them to do it. If it fails for them, well that's a warranty problem and they can't blame you for damage to the camera.
04-07-2014, 07:38 PM   #6
QuoteOriginally posted by calsan Quote
Thanks Calsan,
I got it from Henry's and I've already given up trying to update.
camera, dslr, firmware, k5iis, phase, photography, time, upgrade
k20d upgrade: k5 or k5iis ? voxxonline Pentax DSLR Discussion 13 02-20-2013 10:59 PM
Monopod: 3/8" adapter screw stuck on the 1/4" screw !! jpzk Pentax Camera and Field Accessories 29 04-22-2012 08:00 PM
K7 Firmware Upgrade to ver 1.1 Problem David Lee Visitors' Center 2 10-19-2011 09:21 PM
Cannot upgrade firmware on K10D Jeanimal Pentax DSLR Discussion 11 07-03-2010 09:29 AM
firmware upgrade on istDS j.mbwun Pentax DSLR Discussion 5 07-22-2007 04:57 AM
All times are GMT -7. The time now is 05:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
