Originally posted by fevbusch
I tried P mode but found that it does not seem to work without some kind of further adjustments of which I am ignorant. I also tried that with my old Canon S2is but never got anywhere. according to the books P is an automatic mode but It doesn't seem to be.
I urge you to forget that Auto Pict is even on the camera. I never use it. To be perfectly honest, it seems to me a shame to spend this much money on such a sophisticated tool and then use it in auto-pilot. If you just want to point and shoot, well, even the S2 was more camera than you needed. Not scolding you here. Just encouraging you to pluck up your courage and step away from automatic mode. You'll never go back.
Actually, the camera has many different automatic modes. Auto Pict is fully automatic - you can't really override any of the camera's decisions there. P (program) mode is very similar to Auto Pict. The camera will select the shutter and aperture for you automatically. But you can now fiddle with exposure compensation using the "Av" button on the right side of the camera, next to the power switch/shutter button. You can also control the ISO using P. Av (aperture priority mode) and Tv (shutter priority mode) allow you to set the aperture or shutter speed respectively; then the camera will figure out what the other setting should be.
I think a lot of new users are timid about these settings, but you should not be. While full Manual (M) mode does give you a chance to wreck your pictures, it's hard to wreck them completely in Av or Tv mode, since the camera is still doing at least half of the thinking for you.
Will
