Originally posted by stevebrot The short answer is yes.
The long answer is complicated and has to do with how phase-detect AF (PDAF) systems work. Most of the AF sensor sites for most dSLR cameras have a working aperture of f/5.6. I say most because some cameras (the K-3 being the sole Pentax example) have at least some sensors optimized for f/2.8. The result is relatively poor precision when used with faster lenses at wider apertures.
Contrast-detect (CDAF) systems such as used in live view do not have this limitation and generally provide both greater precision and greater accuracy.
The k5ii series has a single f2.8 basined sensor the the K3 has 3 ... at least the canon 1ds has multiple f2.8 sensors.
As to contrast detect it a double edged sword.... because it works on contrast not phase the camera has no idea which way to focus so has to guess this means performance is so so and in moving targets generally no-no unless the lens is designed for contrast detect (no Pentax lens are).
Also as light drop contrast falls off faster than phase so under low light level CD will fail.
Both PD and CD and be fooled into false locks as they find a peak that is no 'in focus'
As they are both using differential between two points both can only be as accurate as the baseline in use. I have no idea what the base line is for CD off sensor but have not noticed any improved accuracy with Fast lens over PD once PD is calibrated.
