04-24-2008, 07:07 AM   #1
joefru's Avatar
Vivitar 70-210 f/4.5
I have the opportunity to purchase this lens for $25. From what I hear, it will NOT work on my K10D. I found this thread that discusses modifying the lens to fit a K100.
Anyone know anything else about it? I'm stuck right now with kit+FA50, so anything even a little long, even if it's totally manual, would be a blessing for me.
Heck, I'll probably buy it anyway, just to have an old lens. Hell, it's $25!
04-24-2008, 07:15 AM   #2
joefru's Avatar
Actually no, the post I linked to is NOT the same lens that I'm buying. The lens I'm looking at has an "A" setting on the aperture ring. otherwise, it looks identical.
04-24-2008, 07:42 AM   #3
Lowell Goudge's Avatar
There are small screws to remove the flange, and then you can trim it down to avoid the interference.
DO NOT trim the flange in situ, you can scratch the elements and / or fill the lens with filings.
once modified it will work just fine in manual metering mode.
You need to set the function "use apature ring" or simething similar if it is K mount.
If it is KA mount, except for auto focus, you can do every other function in the camera as long as the lens is in the A position.
Out of the A position you can only manually meter using the green button.
04-24-2008, 08:28 AM   #4
joefru's Avatar
It's definitely a KA mount. Is the offending flange only present on the K mount?
Here's a pic:
04-24-2008, 05:08 PM   #5
It seems very much like my vivitar.. and it fits normally on my K10D.
That is a good deal on it. It is a good play-around lens... obviously it shows some purple fringes and it is not that sharp at full zoom... and another issue I've found out the other night while shooting the moon: the freakin zoom was retracting on me! I would set up everything right, place the camera inclined in the tripod and use the timer... after 4 tries I realized the problem: the lens barrel was retracting on me! I started laughing!
Later
04-24-2008, 05:09 PM   #6
Forgot to mention... sample pictures in my gallery!
<---- Click here!
05-08-2008, 05:38 PM   #7
joefru's Avatar
I finally (!) got this lens today. I haven't had a chance to Dremel the offending flange down, but if I take it completely off, it seems to work fine. What happens if I just leave it off?
camera, dslr, lens, photography
DA 50-200 vs DA 55-300 vs Vivitar S1 70-210 vs Pentax-A 70-210; Tele-Zoom Comparo PentHassyKon Pentax SLR Lens Discussion 16 04-28-2010 03:40 PM
For Sale - Sold: FA 50 f1.4, A 50 f2, M 50 f2, Vivitar 28-85 f2.8-3.8, Vivitar S1 70-210 ver. 2 Doanh Sold Items 13 02-09-2010 11:31 AM
Vivitar 28-210 kev.pride Pentax SLR Lens Discussion 0 09-19-2008 10:39 PM
Vivitar Vivitar Series 1 70-210 (62mm) or Pentax 50-200? DMH Pentax SLR Lens Discussion 23 10-25-2007 08:04 AM
Vivitar 70-210, what is this? roy Pentax SLR Lens Discussion 9 07-25-2007 04:43 PM
All times are GMT -7. The time now is 03:54 AM. | See also: NikonForums.com, part of our network of photo forums!
