04-28-2008, 06:48 PM   #31
Otis Memorial Pentaxian
QuoteOriginally posted by morfic Quote
One thing i always meant to test on the 30D and never did: how do K10D meter in stop down metering when using spot instead of average or evaluative/matrix metering.
I once read the theory the closing iris affects how the outer zones meter compared to the still bright center. Always meant to test it, seeing how this is a hot topic here, if i encounter the issue on the K20D as well, i may have to test it. Right now all i can wonder while the cam is in a UPS truck or plane somewhere.
Hope this helps any.
Evaluative metering is disabled when using stop-down metering. Default is center-weighted with spot as an option.
04-28-2008, 07:13 PM   #32
Stratman's Avatar
ahh, ok, I knew full scene metering wasn't an option in "M" mode
04-28-2008, 08:31 PM   #33
morfic's Avatar
Not that i have memorized the entire K20D manual or anything, i just see nothing in it that suggests that, could you point me to some info that shows this limitation to manual == only spot metering available?
I see you all type/answer quicker than me, so who uses their K10D in spot meter, does this affect the amount of (mis)exposure (mis since it seems over or under is both common?)
Thanks,
Daniel
04-28-2008, 09:10 PM   #34
Thanks,
Daniel
A little bit of clarification . I own a K10D, but am assuming that the K20D is similar. This is how it works on my camera (maybe it is even in the manual...).
  • M-mode with DA lens: support for all metering modes (evaluative, center-weighted, and spot). Green button sets an appropriate exposure without stopping down the lens. Stop-down metering is not supported.
  • M-mode with FA/A series lens, aperture ring locked in A position: same as for DA.
  • M-mode with FA/A/M lens, aperture ring used to set aperture: meter mode defaults to center-weighted and spot metering is available. Evaluative metering is NOT available. Exposure is set using green button or DOF preview lever (stop-down metering).
  • M-mode with M42 lens: basically the same as above, but the camera controls do not stop down the lens.
  • AV Mode with M42 lens: defaults to center-weighted with option for spot metering. Evaluative metering is not available. Adjust the aperture and the camera will choose the shutter speed. Very handy.
To answer the rest of your question. I did a few quick tests and YES, metering is flakey in spot mode as well. The general behavior for a particular lens is similar to what you see in center-weighted mode.
Enjoy!
04-28-2008, 09:37 PM   #35
morfic's Avatar
Thanks Stevebrot,
so not much will change for me, i will still get to learn which lens stopped down i will comp how much. Av is what i mostly shot with the beforementioned "intuitive compensation".
I think i should be more disciplined about "M", if i stop down the lens 2 stops, and i had a good exposure, i should change the shutter 2 stops and not get any surprises, but i admit, Av with a little intuition is just so tempting
04-28-2008, 09:40 PM   #36
Thanks Stevebrot,
It sounds like you do about what I do! Good luck with your exploration!
05-14-2008, 12:12 PM   #37
Lowell Goudge's Avatar
see also this link
i appologize for the title, but was a little grumpy after being accused of several things, when reporting the metering issue
https://www.pentaxforums.com/forums/241716-post69.html
camera, dslr, exposure, lens, lenses, meter, photography
EV meter on manual lenses Deiberson Troubleshooting and Beginner Help 17 01-20-2010 11:42 AM
Exposure meter with M lenses. blwnhr Pentax DSLR Discussion 18 07-30-2009 02:06 PM
K-7 meter with manual lenses kmccanta Pentax News and Rumors 2 06-01-2009 02:28 PM
Will the K20D meter with M lenses attached? igor Pentax DSLR Discussion 16 01-28-2009 07:04 AM
k20d ttl meter gone with old lenses arkansas72762 Pentax DSLR Discussion 3 01-10-2009 10:30 PM
All times are GMT -7. The time now is 09:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
