05-14-2014, 03:54 AM   #31
Timd's Avatar
If the camera had GPS, it would not need to keep a real time clock active when the battery was out: it could reset it to the GPS time next time it was switched on. The internal battery is only to keep the RTC operating when the main battery is exchanged, all other functions can be stored on flash memory. Just an out-the-box thought!
05-20-2014, 09:30 AM   #32
GateCityRadio's Avatar
My K100D needed the time and date set every time I put new batteries in it, it kept they user settings though. Never had that issue with the K200D or K7.
09-20-2014, 06:35 PM   #33
QuoteOriginally posted by zekewhipper Quote
You can recharge the internal battery.
1) Turn the camera on.
2) Turn off the Auto Power Off option.
3) Turn off the rear LCD.
4) Let the camera sit overnight. Preferably till the main battery is depleted. That way you can give it a good full recharge too later, but because it obviously put all the juice it could into the internal battery.
That is the method I was shown and that I use when the internal battery gets weak, and it has always worked.
Nup, tried it - Doesn't work with my K-01
battery, camera, capacitor, date, dslr, pentax, pentax dslr, photography, post, settings, time, user
GR -- does it have a built-in lens cover? jon404 Ricoh GR 2 12-13-2013 01:08 AM
When do we get built-in GPS, wifi, bluetooth, and cellular data LTE? dmytty Pentax DSLR Discussion 116 12-18-2012 02:04 AM
Do you have a Micro 4/3 Camera and a DSLR in your bag? vmaniqui Pentax DSLR Discussion 26 02-15-2012 12:49 PM
Do you Do you use AA battery tray in your battery grip? LFLee Pentax K-5 & K-5 II 16 02-04-2012 11:23 PM
What other DSLR do you have? Clicker Non-Pentax Cameras: Canon, Nikon, etc. 8 01-25-2010 09:01 PM
All times are GMT -7. The time now is 01:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
