04-28-2008, 10:52 AM   #1
K20D and long shutter time problem
Hi, when playing with my new K20D I found strange thing - when shooting using long time, then after the shot the camera freezes for nearly the same time as was the shutter time, then only after that period the picture is displayed and writted onto card.
Is it known problem, or just something with my camera ?
04-28-2008, 11:01 AM   #2
Long Exposure
When you do a long exposure the camera by default also does a dark frame shot that the camera uses to remove noise. So if you do a 30 second shot, the dark frame capture will also be 30 seconds. I believe you can turn this off, but I don't recommend it.
Robert
04-28-2008, 11:31 AM   #3
Thanks for fast reply. So it is probably Fn.17 (Slow shutter speed NR) which can be set to either Auto or On (no Off position).
Ivan
04-28-2008, 12:05 PM   #4
KjetilH's Avatar
If I remember correctly, it is kind of broken, some programmer slept at work.
Should be fixed in the next firmware, at least.
camera, dslr, k20d, photography, shutter, shutter time, time
K20d - doubts about live view and long shutter noise reduction... Josť Ramos Pentax DSLR Discussion 16 01-26-2010 05:25 PM
Long time lurker, first time poster... dananielsen Welcomes and Introductions 9 08-22-2009 03:44 PM
K20D Problem with setting date and time gubo Pentax DSLR Discussion 1 02-21-2009 09:32 AM
K20D... a long time coming. OrenMc Pentax DSLR Discussion 6 02-17-2009 08:35 AM
Long time lurker; 1st time post cmstringer Welcomes and Introductions 1 01-26-2009 02:16 AM
All times are GMT -7. The time now is 06:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
