Originally posted by superfuzzy You may not think so, but it happened to me. As long as I can get the actual count from PHOTOme, it is not a problem.
I know you are only keeping a record of how many photographs you have actually taken - but you should be aware that your brand new body will have between 150 and 300 shutter actuations performed by Pentax at the factory as a quality test.
Mine had 242.
I suggest you open that first image in photoMe and note the EXIF record of shutter counts. Pentax probably meant you can never reset the ACTUAL shutter actuations to zero.
Also, PhotoMe says
manual white balance frame and
Digital Preview (if you use that) will count as a shutter actuation and raise the shutter count (hold your cursor over Shutter Count and read the embedded text pop-up).
I don't think you can change the camera body shutter count - only reset the file number counter.
