05-02-2008, 09:03 PM   #1
ennoia's Avatar
shots remaining display?
Hey, just got my K20d - love it so far, but am trying to figure something out...
I have it set so i can change the ISO with the wheel in Av and Tv modes, since the only other way i could find to change ISO is via function menu..
but now i can't see how many shots remain, I checked the "info" screen ... is there some way to see this information without removing the ISO from the wheel?
05-02-2008, 10:26 PM   #2
PentaxPoke's Avatar
Welcome to the club (in more ways than one.) I have my custom menu set to always display ISO instead of shots remaining. Same problem. You only see shots remaining just after taking a picture. Many of us are hoping this is addressed in the next firmware release, so you can see shots remaining somehow without having to take a shot.
05-02-2008, 10:57 PM   #3
ennoia's Avatar
Thanks for the reply - i did notice that turning the camera off shows shots remaining
05-03-2008, 06:19 AM   #4
jlp
At your option, you can set the display to always display remaining shots. By pressing and holding the OK button, the ISO will be displayed and can be changed by front dial. The downside (if it is a downside) is once you have changed the ISO this way, it doesn't revert automatically to the prior setting; e.g., if you have AUTO iso with a range x to y and change ISO via the OK button and front dial, you MUST use the function (Fn) button to access the ISO setting to return it back to AUTO. Other than the AUTO setting, there is no issue (as you can dynamically set ISO to wherever you want it.). This works the same for the K10.
05-03-2008, 07:34 AM   #5
You can either set the camera to show number of remaining shots "permanently", then you can change ISO by holding OK.
Or you can set the camera to show ISO "permanently", then you can see number or remaining shots by holding OK.
(note that the actual behaviour also depends on selected mode, i.e. there are differences between P, Tv etc.)
When you are in mode which can chage ISO by dial, then pressing Green button will set ISO to AUTO.
05-03-2008, 09:21 AM   #6
ennoia's Avatar
cool, didn't know about the ok button - thanks!
05-03-2008, 01:06 PM   #7
Canada_Rockies's Avatar
QuoteOriginally posted by jlp Quote
The camera will revert to AUTO ISO if you press the OK and then the green button. The green button is Pentax's magic button to return to default settings.
camera, change, dslr, iso, photography, shots, wheel
Macro The Only Flower Remaining GoremanX Photo Critique 2 02-07-2010 12:06 PM
K-x display # shots in viewfinder opiedog Pentax DSLR Discussion 4 12-06-2009 05:11 AM
No. of Shots vs ISO Display atnbirdie Pentax DSLR Discussion 10 09-29-2009 12:39 AM
Remaining K-7 Tour stop locations JCPentax Travel, Events, and Groups 1 08-05-2009 02:00 PM
Number of pics remaining on K20D? Kguru Pentax DSLR Discussion 8 12-15-2008 03:55 PM
All times are GMT -7. The time now is 01:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
