Originally posted by nomadkng the other problem is potential cascade failure. when one chip/circuit goes, often it takes others with them. I see this all the time in my line of work, what seems like a simple component replacement ends up being an elaborate repair process. it's probably why they wanted to replace the whole board. it can get VERY expensive chasing failed chips/circuits. With the cost of labor close to 100/hour, a repair company can't afford to make time costly mistakes.
as it's been said about consumer electronics, by the time the warranty has expired, it tends to cost more to repair it than replace it. it's another reason why individual quantities of components aren't stocked. there's really not a lot of market for repairs. take the case of my K5iis. with it going for a bargain basement price of 700, based on your quote, I'd be better off buying a new one for the same price. Even with the base price of a board at 400, I'd have to think very hard if I wanted to spend 400 to repair or 700 to replace
Long ago I expressed your idea as "Even after I spend all that on repairs I still end up with an old one."
I was actually talking about the problem of major repairs on an aging car.
In electronics a root cause these days for not stocking parts is that the parts fit one model, because all the parts are special purpose, whereas back in the Heathkit days the parts were piece parts that could be applied to a list of purposes and probably common across many products. And there were books of equivalents so replacements were not uncommonly done with the nearest available equivalent, not the original device.
We have also seen the effect in the decline of jobs in the highly skilled technical areas.
