05-04-2008, 01:36 PM   #1
K10d Viewfinder issue-help please
I have a question about the viewfinder in the K10. I have read in several articles and in several posts on this site that the viewfinder is very "bright and clear". I finally got to take my new K10 out for some shots in the daylight (I work overnight and this is sometimes hard to do) and I noticed something.
To me, the viewfinder seems quit dim. When I looked at a white gravel road or the sky there is also what appears to be several hundred little black dots all over it. Maybe dots is the wrong word...its more of a 'texture' really. Its not to terribly distracting but its also not what I would describe as bright and clear. The Nikon d300 I tested in the store (now that I remember) had a much brighter viewfinder.
Does anybody else have this problem? Is mine just defective or is this normal for a Pentax viewfinder. I am coming off of a Canon Reble XT and it did not have this texture issue.
Also, one other question. I cant quite tell if my diopter is set correct. Will a messed up diopter setting actually make you take blurry pictures?
Any help you can give would be great. Thanks.
Bokeh
05-04-2008, 01:45 PM   #2
Matte screen...
which helps You to focus manually- brightness is not all, functionality matters IMO :-) And also as all viewing with modern lenses is made at maximum aperture visual brightness depends on glass in use: with F/1.4 it is superbright and with consumer grade F/5.6 it is... as You guess 4 times darker- this is optics, not a viewfinder here- and no camera can help here (except P&S with gained up LCD view).
Best and happy viewing through eyepiece, JR
05-04-2008, 01:45 PM   #3
A. The focusing screen on the K10D is matte. I suspect that's the pebbly look you're talking about.
B. Set the diopter so the lines on the screen in the viewfinder are sharp. The diopter has no effect on the picture unless you're manually focusing and the diopter is off. Then you'd manually focus incorrectly.
05-04-2008, 02:12 PM   #4
Thanks guys, the matte screen is what I was talking about. Didnt know it was supposed to be that way.
05-05-2008, 01:28 PM   #5
deludel's Avatar
Personal "DUH-LORI" story here ... I was having issues with a dim VF, even posted something here about it ... I could barely see the EV information, and it was driving me nuts.
Then I realized .. it was only happening when my sunglasses were on ... Took off the sunglasses and voila - problem solved.
05-05-2008, 02:01 PM   #6
Lowell Goudge's Avatar
QuoteOriginally posted by deludel Quote
For a moment there I thought you were going to say you took off the lens cap
05-05-2008, 09:20 PM   #7
Canada_Rockies's Avatar
Nah. With the lens cap on the green numbers are really easy to see.
camera, diopter, dots, dslr, k10, photography, question, viewfinder
Pentax K-X - Issue with viewfinder mrmp3 Troubleshooting and Beginner Help 3 10-22-2010 11:53 AM
Viewfinder Mirror issue AbsoluteZedo Troubleshooting and Beginner Help 27 10-20-2010 07:45 AM
Leaning viewfinder on K10D matsoberg Pentax DSLR Discussion 125 01-25-2009 02:36 PM
viewfinder issue jag Pentax DSLR Discussion 28 01-07-2008 08:48 AM
Viewfinder Issue... NYpHoToGraphEr Pentax DSLR Discussion 11 11-09-2007 10:00 AM
All times are GMT -7. The time now is 06:38 PM. | See also: NikonForums.com, part of our network of photo forums!
