06-30-2014, 04:23 AM   #1
Shake reduction & UWA lenses
Do you think or have you experienced any adverse SR effect when shooting with ultra wide angle lenses like 10mm and scene with a lots of small detailing ?
Yusuf
06-30-2014, 04:48 AM   #2
Na Horuk's Avatar
The Samyang 14mm is exposed to a potential problem because on most Pentax DLSRs you cannot input 14mm as the focal length. If you choose 15mm, the SR can overcompensate, though, and cause blur. So I prefer to choose 12mm. But when I use my UWA I almost always turn off SR, since UWA means you can have a pretty long exposure if your hands are steady. Best is with tripod and 2 sec timer, which automatically turns off SR anyway.
06-30-2014, 05:45 AM   #3
Actually it's Sigma 10-20 so inputting focal length was not an issue. The shutter speed was > 1/250s. However, pictures seems to have blur when SR was ON, especially in shots with minute details like trees, leaves etc, pictures with SR off are acceptable though. The blur is not so noticeable for larger objects even when SR is ON.
06-30-2014, 06:03 AM   #4
Bruce Clark's Avatar
I have this lens and have not noticed any issues. Perhaps if you post a few samples it would assist in diagnosis.
06-30-2014, 06:05 AM   #5
tabl10s's Avatar
There's no substitute for good technique. Must like a cell phone, at one time, there was no such thing.
06-30-2014, 06:10 AM   #6
normhead's Avatar
Not at all.... I shoot with a Sigma 8-16 from time to time, but then, I often shoot on a 2 second times and a tripod and SR is turned off. From time to time I do use the 8-16 for candid off tripod type images and it works fine.
Hand held, ƒ8 , 11mm , 1/2000, no noticeable loss of detail.
SIgma 8-10 @8mm 1/1000s, SR on, razor sharp, even pixel peeping... it has gat that funky wide angle distortion on the edges look though...heavy correction doesn't end distortion, it just gives you different distortion.
06-30-2014, 06:32 AM   #7
Possibly a k-x specific issue, I no longer have any Pentax DSLR to try this out again but this was the observation while looking at some old pictures. Also, as I said, it's very evident when there are minute details like leaves, far mountains with trees, etc but not on larger objects. Will post some pictures later.
06-30-2014, 07:15 AM   #8
jatrax's Avatar
K-X shake reduction took some time to lock in. Not an issue once you got used to it but if you shot before SR stabilized you could get blur. I have not noticed this on newer bodies.
06-30-2014, 10:28 AM   #9
Good point. So I checked with PhotoMe and it shows SR was stabilized in all the shots so that doesn't seems to be the problem.
camera, dslr, lenses, photography, reduction & uwa
K5 II video shake mechanical or electronic shake reduction? Rice Pentax K-5 & K-5 II 3 06-14-2014 02:51 PM
shake reduction with full frame lenses Hiroshi Troubleshooting and Beginner Help 7 05-01-2014 03:39 PM
Adapted Lenses & Shake Reduction Settings littledrawe Pentax Q 16 03-26-2014 11:05 PM
Sensor & Shake Reduction Wingincamera Pentax K-5 & K-5 II 10 05-14-2013 12:11 AM
Shake reduction & camera life Brew1brew Pentax DSLR Discussion 9 09-27-2006 05:58 AM
All times are GMT -7. The time now is 08:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
