Originally posted by Yael I guess the other logical question is, is there any reason to keep any of those old flashes around when the K100D has built-in flash anyway... Is the built-in flash superior to the older flashes or about the same or?
Your 3500 is significantly better than the built-in flash (more powerful = more light). Here is my suggestion on how to use it.
a. Set your camera to manual mode
b. Set the shutter speed to 1/125 sec.
c. Set the aperture to your desired setting. Somewhere in the f5.6 to f8 range.
d. Set the ISO to about 400.
e. Set the settings on the back of the flash to match your camera settings.
There is a sensor on the front of your flash that will meter the amount of light reflecting off the subject. This will tell the flash when to shut off. If you pictures are dark, you may need to bump your ISO (and reset the flash), as your subject is too far away to get proper exposure. If you pictures are over exposed, you will need to drop your ISO to decrease the amount of light the sensor sees.
Hope this helps.
Tim
