05-06-2008, 07:09 AM   #1
How to disable autofocus in K10D?
When shooting panos I read that I should disable autofocus for the shots. So how do I do that with the K10D for autofocus lenses?
05-06-2008, 07:17 AM   #2
RTFM, that's how I do it! I set to "MF"!!!
05-06-2008, 07:36 AM   #3
alohadave's Avatar
QuoteOriginally posted by Zilla Quote
You can also decouple the AF from the shutter button to trigger or override AF so you won't need to switch from AF-MF.
05-06-2008, 07:37 AM   #4
ftpaddict's Avatar
RTFM usually answers most questions.
05-06-2008, 07:44 AM   #5
There are some options. I normally have my camera set to focus on a single point but the auto-focus is not on the shutter button but on the AF button on the back of the camera.
05-06-2008, 08:38 AM   #6
Lowell Goudge's Avatar
I think you should be commended for recognizing you need to read the manual. Many dont!
05-06-2008, 09:23 AM   #7
joefru's Avatar
I groaned when I read the title of this post, but I'm glad you got it on your own.
Also, if you hold the AF button to lock focus, it will not try to re-focus when you press the shutter, as long as you continue to hold AF. If you're doing fancy, tripod-style panos, this is not useful, but if you're seat-of-your-pants-ing it, it works pretty well.
(Yes, alohadave mentioned decoupling, but this doesn't require a custom function. OTOH, it's not as elegant.)
05-06-2008, 09:55 AM   #8
I just push all the buttons until I figure it out
05-06-2008, 10:08 AM   #9
I've RTFM'ed several times, and even bought the K10D book, which goes beyond the manual. I just had a brain fart when I posted this.
autofocus, camera, dslr, photography
k10d Autofocus hunting Joel_H Pentax DSLR Discussion 11 12-27-2009 10:04 AM
K10D Autofocus problems Joel Pentax DSLR Discussion 5 05-03-2008 07:06 AM
K10d Autofocus Tracking Workingdog Pentax DSLR Discussion 28 12-11-2007 05:40 AM
autofocus vs manual (new to k10d) REDEYE Pentax DSLR Discussion 18 07-24-2007 02:10 PM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, part of our network of photo forums!
