07-24-2014, 08:14 PM   #1
K10D SDHC Cards
I need to get some SD cards for my K10D and have a few questions. I can't see where the K10D manual specifies a minimum speed class, but I'm looking at class 10 cards, since I figure that even if the camera can't write at the card's rated speed I can read them faster on the computer. I can also use them in my HD camcorder, which only requires a minimum of Class 4 or 6 (I don't remember for sure.)
1. Do cards labeled UHS-1 work in a K10D? I've read here that some cameras don't work well with UHS-1 cards.
2. How fast will the K10D write to the card? I see all kinds of write speeds listed for various cards.
3. For two cards rated the same write speed, will using a larger card, like 16 or 32 GB cause any slowdowns in the K10D over a smaller card, like 4 or 8 GB? I'm wondering about "overhead" for the camera to wade through a larger number of files.
4. I'm at firmware version 1.30. I see that version 1.31 is available for "Improved recording stability when using some SDHC memory cards." Does anybody know what this specifically addresses?
5. Are there any brands that perform better in this camera? Lexar, SanDisk, Transcend, Kingston, PNY or eBay specials work just as well?
6. Do MicroSDHC cards with an adapter work?
EDIT: I found this on Lexar site:
Can I use an UHS-I card with a SDHC host device?
Yes! All SD UHS-I cards can be used with all existing SDXC and SDHC devices (backwards compatible). Note that SDXC UHS-I cards are not compatible with SD or SDHC host devices, only with SDXC host devices.
But I'm sure I read here that some people have had problems with Pentax cameras and UHS-1 Cards.
Thanks in advance,
-Dave
07-24-2014, 08:50 PM   #2
calsan's Avatar
Yes, make sure you are running firmware 1.31. (i.e. the latest) Then you will have full support for the largest capacity SDHC - which I think goes up to 32GB. This is totally over the top storage for the K10d. I reckon 2GB cards were all I needed when that was my main camera. Maybe lash out and get 8GB or 16, you will never run out of card space!
I can confirm that Sandisk Ultras are fast enough for the K10d. I've never had trouble with any sandisk cards - just make sure that whatever brand you get it's actually a genuine card... I would skip ebay for this reason.
Sandisk Extremes (confusing superlatives with sandisk) don't perform any faster, as the camera isn't fast enough to justify them, so you can save some money there.
I can't see any reason why there may be an overhead with a larger card, because the card (or any disk) uses a directory to look up where files are stored. A bit like checking the index page, rather than randomly flicking through a book.
I wouldn't get a microSD card with adapter - there's a small risk it could pop out of the adapter and get stuck in the camera.
07-24-2014, 09:10 PM   #3
Zealex's Avatar
SanDisk Extreme is a very popular brand. However, I use PNY cards which are cheaper and don't have a complaint. It's 9.99 for a 16gb 90mb/s card on Amazon. I wouldn't get less than 16gb because the price asked for 8gb cards is like a dollar cheaper than 16gb.. Another brand of SD cards people here like I believe are Transcend. SD card speed is the same I believe regardless of memory space. If the speed is advertised at 30mb/s a 64gb and 8gb should read at the same rate.
07-24-2014, 09:11 PM   #4
Brooke Meyer
Guest
I can't remember what I used with my K-10. I went a pair of K-20s and used 16 GB Transcend Class 10s. Any good brand Class 10 is plenty. B&H or Adorama,
Here's an 8Gb Class 10 Transcend for $7.95 and Free Shipping. Go crazy and get two!
Or go big for $9.99 16 GB Class 10 Transcend and Free Shipping
07-24-2014, 10:58 PM   #5
QuoteOriginally posted by DaveNC Quote
1. Do cards labeled UHS-1 work in a K10D? I've read here that some cameras don't work well with UHS-1 cards. 2. How fast will the K10D write to the card? I see all kinds of write speeds listed for various cards.
Yes, UHS-I SDHC cards will work, but you won't benefit from the extra speed. The K10D writes at under 30Mb/s so even a cheap sandisk class 10 card will give you optimal performance. I'd recommend sticking with Sandisk or Lexar as far as brands go.
07-25-2014, 10:30 AM   #6
Thanks!
Thanks for the replies! I'm glad to hear the UHS-1 cards will work since they're the basically same price as the regular Class 10 cards. Even if the K10D won't utilize the extra speed, hopefully my next camera will.
Brooke, that looks like a deal on the 16GB Transcend cards. I may have to try a couple of those.
And I'll get the latest firmware update installed.
-Dave
07-25-2014, 10:37 AM   #7
Zealex's Avatar
Just a tip, SD cards when advertised usually display reading speeds. If you shoot in bursts, you'll want cards that can deliver writing speeds of 30mb/s (or more) to clear that buffer ASAP. Reading speeds are usually much greater than writing speeds, so keep that in consideration!
07-25-2014, 01:43 PM   #8
Thanks for the tip, Zealex. Something else to look at.
-Dave
07-25-2014, 04:41 PM   #9
Brooke Meyer
Guest
You're shooting a K10. Worry about the exposure and composition. Don't worry the memory card write speed. The money you save will go towards a tripod and manual shutter release.
07-25-2014, 05:09 PM   #10
Nice Photo!
Nice photo! Is that from somewhere along the Outer Banks, Highway 12 on the right?
07-25-2014, 05:20 PM   #11
Brooke Meyer
Guest
Dune walk over across from the Visitor Center at Pea Island, April 2009. If taken now, you'd see the "temporary" bridge.
K10 with my first lens, a Tamron 28-75 which I shot today on a K5IIs.
camera, card, cards, class, dslr, gb, k10d, photography, sdhc, uhs-1, version
2x 32Gb Lexar SDHC Cards: $39.95 Adam Pentax Price Watch 8 02-12-2014 12:48 PM
K-5 And Sdhc cards sqjaw Pentax DSLR Discussion 19 04-10-2013 08:50 PM
Transcend SDHC WIFI Class 10 Cards David Pentax Camera and Field Accessories 9 01-23-2013 03:42 PM
SDHC Card Test 3, New Cards and USB Reader davidreilly3207 Pentax DSLR Discussion 7 12-04-2012 03:28 AM
For Sale - Sold: K10D, *ist D, FA 50 F1.4, 2 Tamrons, AF500FTZ, grips, SDHC cards, Flash cord Truax_photo Sold Items 19 07-25-2008 12:42 PM
All times are GMT -7. The time now is 12:28 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
